  • Replies 120
I jus got home and read the thread, i was comming down the highway and ran into a what was a done up mid 90's WRX i have a fully stock R33 Gts-t and wait for it... Automatic as well. (by the way a 300zx was on the other side) and it was on. Lights went green and it was on, belive it or not i ripped him at the start and i hit a 120 b4 him but had to slow down cos it was a 80 zone and coppers was everywhere. Then he zoomed past as if he was a hero. it was a loud car. the 300zx was no where to be seen. So there. I ripped a Rex with a automatic skyline. Thought id add my 5 cents worth. But dont get me wrong. Wrx's are nice cars as well. But come on, at night when suns gone down and those 4 red circle lights at the back shines, how could u ever go past a skyline? maybe they made the back good looking cos thats all the Wrx drivers will see :P
stock vs stock - it comes down to the driver, DJ: if you got majorly ripped by one it could of been because of mods!
300 ZX Twin Turbo
2 Seater VG30DETT 2997cc Quad Cam 24 valve EFI V6 Twin Turbo 208kw @ 6400rpm 388nm @ 3600rpm 7200rpm 1490 kg 5.96 seconds 14.20 seconds
Vs
Skyline R34
25GT-Turbo RB25DET 2498cc NEO DOHC 24 valve EFI Straight 6 Turbo 206kw @ 6400rpm 343nm @ 3200rpm 7000rpm 1410 kg 6.00 seconds 14.20 seconds
My is a 95r33 and me mate own a 98wrx and i smoke him two car lengh with stockie boost and 3 car lengh with 12psi but always in sencond gear onward cos them 4wd take off faster. Now my with exhaust, run 12psi i made 191kw@tw, and a week before i bought this CHIP stockr33 comp off BIGPSI BIG FELLA and the power i got was just amazing, it got rid off the speed limiter, rev limiter and top end power is just amazing. Kill me mate GTIr in third gear with 1st and 2nd spin hard.
I reckon if i have a proper size intercooler and a bigger acttulator to hold boost i can manage around 230kw@Rear. So tell me why Rexs can beat a GTR when even our shitty GTsT can manage that much??????
west... what have ya got on your gtst ?? i assume a bigger turbo with that power ? im wanting to pull about 190rwkw once my intercooler is done, but i have full exhaust, safc, boost and intercooler and am hopiung for that, cant see how u could get more than that without some other mod like turbo etc???
DJ_L3THAL, I've got 190rwkw and I've got a full exhaust, intercooler, air filter and Apexi power Fc running 12-13psi on standard turbo. You'll need to hi flow or change the Turbo for any more...You'll the need to feed the beast with more either bigger injections or fuel pressure regulator and a new fuel pump...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
