All i have was a BEND supra intercool, custom front pipe and N1 catback with Hi-flow cat, Pro FectB controler, air filter and at 12psi i made 191 already which could have gone a bit better but run out of cold air( cooler size ) and said 12psi but i was actually 10 cos stock actullator dont' hold. Now with BIGPSI chip computer( some KAIRAIYA RACING SERVICE stick on the computer ) i have no problem with short of fuel at all, before runing at 12 and sometimes i got this sudden stop cos not enough fuel. SOme of us have good power figure to their car while some doesnt i peronally think it all depend on the condition of our engine too. Oh by the way my turbo is stock, yeap it's stock DJ.
  • Replies 120
Oh and i don't belive a stock Z would beat a stock skyline even if it's not an r34. One night along princes HWY, i draged with a blue xf or xd ford, a hsv vs supercharge and a 300z. The FOrd and the HSV was even, my is like two car lengh behind ( back then i had no mod on mine ) and gues where the Z is? about 3car lengh behind me!!! Pull up at the light, wind the window down, ask the Ford guy and his car was a 12sec car, so is the heavyly boost supercharge HSV. There we go, if you guys read HPI oftenly, you guys will see that the VQ engine was the worse NISSAN ever made. Sorry if i may sound insult any Z owners out there but this was just a little personal though, i know there are fast Z out there but consider the $$ that they put in their car then use that $$ to mod a skyline then you'll see the DIFFERENT.
Originally posted by DJ_L3ThAL
what are the sp3ecs of a stock 33 gtst ?
Dude I thought you would know what your cars base power / specs are, anyway here ya go:
Skyline R33
GT-ST-25T RB25DET 2498cc DOHC 24 valve EFI Straight 6 Turbo 187kw @ 6400rpm 295nm @ 4800rpm 7000rpm 1390 kg 6.18 seconds 14.39 seconds
these are average figures of course :)
had a run with a wrx last night actually, modded [arent they all], got a shit take off [didnt know it was ON really] but he started similar then bang he pulled hard but never caught up! Took me 2 goes to hit 3rd gear but this still wasnt enough for him to catch up :D
I chose the 34 GTT! But at the time 33 gtr's were no less than $40k I didnt have the funding for that much.
All i can advise is test drive them both to see what suits you better - looks wise i prefer 34 but thats just me!
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
