Hi guys,
Got a little problem with my 34 Basically this is what it does. When I first start it up it sits at 3000rpm for about 5secs then drops down and hunts between 1000-2000rpm. Also when I’m driving and back off the throttle has a small delay and then starts decelerating other than that it runs fine.
Any ideas would be much appreciated
Thanks.
https://www.sau.com.au/forums/topic/151744-r34-gtt-dramas/
It could be stuffed...not being picky, but did you clean it really well. My one was soo coked-up it was solid, I had to soak it in metho to get the 'piston' out.
Basically unscrew the stepper out and remove all components.
https://www.sau.com.au/forums/topic/151744-r34-gtt-dramas/#findComment-2829378
clean afm using contact cleaner..often happens
I heard several ppl having same missfiring problems after they change to 3" exhaust and fixed it by changing spark plug gap...don't know the details but it's here somewhere 5-6 months back I think
https://www.sau.com.au/forums/topic/151744-r34-gtt-dramas/#findComment-2841900
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
