  • Replies 58
you can be summonsed to the epa for any reason
for none at all if they wish, they could summon your mums stock vp commodore to the epa if they want, high unlikely but they can.
and this happens. I Vic member of my FTO club was "selected at random" by the EPA. This car was fully stock and the guy who imported and drives it is 60 yo. They got him for from indicators were not visable from 45 degress
If they want to defect you they will. they will find something...
the idea then is to get rid of the defect notice not the defect...
IT depends on what sort of day the copper is having... My step father is an ex cop, It's interesting hearing it from the cops side of things. But when it comes down to it they are just people and suffer from jealousy, envy, they get irritable and cranky. You really just need to talk to the right people in the right way and sometimes money and favours help as well...
hehe so your saying we should try bribe the cops or something :yes: ?
no offence, but fark that.
I'm beginning to get sick of 'alleged' police picking on import cars... but at the same time I'm getting sick of hearing "oh i got defected / EPA those bastards etc"
FFS if your car is modified, too low, too loud etc then it is illegal. Exactly the same as when a BMW is loud, lowered, etc it will DRAW ATTENTION.
"TUNED BY FULLY SICK MATE" in 2 foot stickers on your window will attract attention...
It is something that you have to live with; if you modify it's in your hands.
I hope you don't get EPA'd - I have, but it's a risk you run and you should know that when modifying.
yeah man, not you, but all the helpful cop-bashing posts subsequently...
good luck though, hope you don't get one, or if you do you're car can be returned to stock(ish) easily enough!
oh and just noticed your other question; wrt to RWC-
if you get a full EPA notice you HAVE to go to the inspection; a RWC is not sufficient to clear it!
Yeap,
Totally agreed, its a part of the game.
That wasn't EPA Chris.. it was Vicroads ADR inspection for anyone whose car had undergone compliance with a couple of workshops due to them being dodgy/not fully doing the compliance work.
well i was just going to see a friend and ended up getting a major defect lol need a engineers doc now and will be getting sent to mcleod. Thinking about selling my car but then i guess they've one lol. Fkn the bacon out there cant differentiate between the hoons and the real car enthusiasts.
Guys, cops are clamping down hardcore and are trying to do there job to the best of their ability.
The only way not to get caught is to drive the following
Commodore VL to VE
Falcon XD to BF
any small 4 cyclynder vehicle non-turbo.
end of discussion.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
