http://news.ninemsn.com.au/article.aspx?id=68809
why i am confident that this story wouldnt possibly be directed at any Skyline drivers... maybe its better to buy an old sigma or something for a while and avoid the usual spots?
you know usual knee jerk response becuase of a few little f**ks.
https://www.sau.com.au/forums/topic/152035-oh-victoria/
bloody hell....stupid f**kers always come and f**k up the lives of true car enthusiasts.....im soo f**king sick and tired of that shit.....
https://www.sau.com.au/forums/topic/152035-oh-victoria/#findComment-2828889
There really isnt a lot they are going to be able to do.
As we saw, the Police couldnt even act accordingly when they knew something was going to happen.
If they dont know about it till it happens, then they stand very little chance of doing much other than... well... nothing.
Of course, breaking up something thats gone on for two hours or more they will hail as a success from the gods... but we all know its just propoganda.
Much like the comment at the end
"The party is over for these people. We will show no tolerance. We will target irresponsible driving behaviour and will seize their cars."
The hoon laws have been around for a while now, and oh look... its really stopped the misbehaviour...
https://www.sau.com.au/forums/topic/152035-oh-victoria/#findComment-2828918
Pfft, they are so weak already, asif they are going to try anything outrageous..it will only end in the real car enthusiasts copping it, yet again, good one Victoria!
When will they get some clue and target the little shits that are drinking and watching these morons ripping their burnouts, instead of targeting the cars, if you remove the hoons little fanboys, they won't rip their burnouts..just make it legal (or if it is already, then do it) to just use agressive force against these crowds (and make it known it will be the case), rubber bullets, tear gas etc..far out, we live in SUCH A WEAK COUNTRY, get some backbone Vic police. **** they must be brainless.
https://www.sau.com.au/forums/topic/152035-oh-victoria/#findComment-2829158
Do you have any police presence at cruise meets? If they are going to try and stop gatherings maybe there will be police coming through and checking cars (maybe defecting them)...thats not a good thing
We have had the Police turn up to an organised club car cruise as we stopped to get some lunch. Basically, any time a large group of cars that look nice and modified etc, will get the attention of someone. It may be a member of the public which is concerned, or a local highway cop wanting to be a part of the action.
If you haven't done anything wrong, then you have nothing to worry about. If you have a big turbo, aftermarket this and that and the other thing that doesn't comply with the guidelines written by VicRoads, then that is your own problem.
In the end, the Police are just doing what they are paid to do.
https://www.sau.com.au/forums/topic/152035-oh-victoria/#findComment-2829514
for once i actually agree with ash...
just more propoganda bullshit. and yeah... hoon laws did a great deal of good lol
https://www.sau.com.au/forums/topic/152035-oh-victoria/#findComment-2831858
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
