Hi guys,
RB26, JB clutch and stock flywheel
- Car has firm (but not overly hard) suspension
- Bit of a resonance issue at cruising speeds (from exhaust)
- Shifter will pop out of gear after about 5 min on the highway, or bit earlier if the road is a bit rough
What should I start looking at to fix?
Cheers...
https://www.sau.com.au/forums/topic/152427-shifter-popping-out-of-gear/
  • 2 years later...
If it happens when you back off more than likely you have a worn gear ( the one that pops out)
mine pops out of the tops gears, i have removed the gearboot and it helped for a while, but it still does it does that means the gears are destroyed? it maybe the 300rwkw goin through it though lol....
Yer you'll be looking at replacing the synchro hub assembly mate...won't know for sure until you pull apart the box but those are the symptoms that usually go with it. In a way it's good because there's no bullshit bandaid solution like using a different grade oil to silence problems, forcing you to repair it properly hehe :D
Bout $1000 to recondition it mate, plus the labour of pulling the gearbox out / installing it again. Oops, I just realised you aren't the OP that I originally addressed my questions to lol. Same problem anyway...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
