Hello members of SAU,
Nisswreck has just become a sponsor on SAU!
We specialise in dismantling all Nissans as well as a few Toyota's such as MR2, Soarer, celica's. We also sell complete cars for either street or track use.
We have a LARGE range of stock and we have been in bussines for 16 years!
We are located in South Australia BUT can freight to anywhere in Australia!!
ALL SAU MEMBERS WILL BE GIVEN DISCOUNTED PRICES!!!
Nisswreck have been a sponsor on nissansilvia.com for a while and have become a well known/trusted trader
See our feedback from nissansilvia.com members: http://www.nissansilvia.com/forums/Nisswre...ad-t154860.html
Please visit our website www.nisswreck.com.au
Currently dismantling- R31, R32, R33, R34 Skylines turbo and non turbo
- Cefiro A31
- Laurel C33
- Stagea C34
- S13, s14, s15 silvia/180sx/200sx
- Pulsar GTI-R
- Cima/Cedric Y31
many other imported models
also most australian Nissan models. ( Toyota Mr2 sw20, celica and soarer parts in stock as well)
So if there's any part big or small you need for ur car just ask us!
Cheers
Steve
https://www.sau.com.au/forums/topic/152683-nisswreck-now-a-sponsor-on-sau/
  • Replies 44
Nice..
I'm after a few bits.
R32 Heater Core (mine is leaking)
R32 Aircon Inlet Air Temp sensor (located in the heater/aircon box somewhere its causing my A/C not to work)
Not looking forward to pulling mine apart next week. :S
Let me know what you can do. :P
Welcome to SAU Guys!
Nisswreck are awesome guys, I've ordered HEAPS of parts from them in the last 6months and am VERY happy with the quality, price and service!!! No doubt they'll be the first point of contact for my new project.
cheers
Liz.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
