starting this thread for anyone who wants firmer shifts in there auto without a shift kit . was having a few problems wit my trans slipping in third gear and first so took her to the shop. The car has a warranty so told the guy while it was appart that i wanted a shift kit installed cos it would be cheaper. when he called back he told me that i had a leaky solenoid and there was a lot of tarnish on the valve body, then he mentioned the Shift Improver and from its description could probably claim it under warranty. It claimed that it would extend gearbox life by firming up 3rd quite a lot and other gears aswell. the shift improver cost round 250. This is a good idea if you want firm shifts but not a shift kit as they can change gears alot harder. anyways i am happy with the end product. nice firm shifts that dont break ya neck. has anyone else had one installed.?
https://www.sau.com.au/forums/topic/152782-auto-shift-improver/
its modifying the valve body. bigger springs new valves and drilling bigger holes in a plate to let more fluid through to firm up the shift .its like a shift kit just a mild one but stiil gets a heap better shift than standard
There are different versions of shift kits available from MV Automatics in SA (stage 1, 1.5 and 2 i believe), I went for the Stage 1, the mildest, prob similar to yours, only feel the changes from 1st to 2nd, others are smooth, but very quick, no more flaring.
Not sure what stage I got but I had mine installed at MV automatics (I live in SA). $440 including a transmission service so not expensive at all.
My shifts are pretty much transparent when I want them to be or a bit more clunky if I drive it hard. I normally feel the 1st to 2nd shift but after that its unnoticeable.
Like everyone else, I get very solid, quick shifts and I'm very happy with that little mod.
And yes it apparently improves your auto box not weakens it. :glare:
it saves your clutch packs from slipping before it is fully in the next gear by letting more fluid through the valve body to push the packs together quiker. you have 2 sets of packs. 1 for 1st and 3rd gear and the other for 2nd and 4th. the weakest shift is 2nd to 3rd.
No, it is a specialised job, there are only a few places who know what they are doing with the RE401 boxes. If you have the time, get a shop to pull out the valve body, (or better still, find another one), then send it to Mike at MV Automatics in South Australia, tell him what stage you want, he should send it back after a couple of days.
Edited by chook
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
