hey mate you have any rear brake lines? do you know if there the same as gtst, im in need of a brake line that runs near the caliper
  • Replies 117
can you PM me what comes with complete motor ie injector/stock turbos ect,
hi mate injectors, rail,plenum, clutch fan ,all belts,stock turbos never been boosted, diff sump,boost solenoid, backing plate behind flywheel,clutch and flywheel,all rear heater hoses,harnes,coil packs all rb26 covers ,ignighter , AC COMPRESER, ALTERNATOR EVERY THING IS ON THER the way it came out nuthing has been removed at the price and condition it wont last long if interested call me on 0410 388 994 for inspection
I am also keen for the detials on the Weds. Size, Width, offset and an approximate price perhaps?
hi mate will get back with details been very busy if u want to buz me 0410 388 994 to get details qicker weekdays any time after 130pm cheers or weekends anytime
