you are right they are on tight. And they need to go back on tight too.
I used a standard socket set and brute strength to get my bolts off, I hit my hand twice (very #%$*n hard) and can't reccomend this method, so go the rattle gun if you can get one.
Just a qik question to all the home mechanics, need to change my clutch soon... so when you guys did yours, how did you raise your cars to get the gearbox out (if at home)?
My mate was telling me theres a bolt right at the top of the bellhousing thats a pain to get to and needed a very long extension.. he also told me he neede 4 ppl to get the box out...??????
To all those people wanting to put extenders on their ratchets - my advice is don't. It will probably work several times, but it's not healthy for the ratchet at all because it's relatively delicate inside.
You should buy a "breaker bar" which is about $40 from a good tool shop, which is designed for this purpose. It's about half a metre long and works really well with extenders. Because it's a lot longer than a normal ratchet a lot of the time you won't even need the extender.
Or buy a sydchrome toolset, if they break they replace it for free.
Stop buying your tools outa the bargin bin at kmart! :shake:
hey,
well i have experienced undoing theauto driver plate flywheel. it attributed to 8 of the best stitches. Then i found out about a using the trolley jack bar ontop of the ratchet. Basically get another long ratchet bar for the front bolt. around 40cm, and lean it up against the chasis so its doesn't budge. put a towel underneath so u dont scratch if you want.
then just get under the car, and with your trolley jack bracker bar, you car do the flywheel bolts undone. I used the long socket set of ratchets. 17mm, or 19 mm. cant remember.
Put pressure on the bar slowly. in the anti clockwise direction, and the bar holding the front bolt, will put force against the crank so it doesn't spin or slip. and the flywheel bolts will come undone.
and you should save your self a lot of trouble and 8 stitches.
When putting the box off i just put a trolley jack under the plug of the box, and lowered it. I have done this around 5 times now in 2 weeks, for my car.
Getting to the top bolt in the difficult place, i just jacked the car up high. (setting trolley jacks on highest setting). And then lower the back of the box, so it goes on angled, and so does the motor. thus you can access the bolt. (if i can do it in the s13 tunnel u can do it).
u probly already done it, but felt like typing.
hehe.
(lining up the clutch with the spigot bush is another story, stuck on that at the moment).
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
