spotto Luke a couple of times, black 32 on the outlet heading kingo way and also a maroon 33 heading towards kingo too.
hahaha are you folowing me?...(joke) :O .. man that 33 is nice... ;)
spotting heaps of black R32's of late... ;) .hahahah probly the same one... :)
who's skyline was it? my g/f noticed what she described as a "purple or pink skyline" 2day at the old ampol (24hr) servo earlier 2day. she's not down with the models yet and could not tell if it was a 32 or 33, but said it was damm nice and there was about 4-5 blokes standing around it drooling, anyone know who's ride it is?, damo
Spotted:
R33 GT-R - I can't decide if its midnight blue or midnight purple - with gold advans....seemingly EVERYWHERE I go. I swear I see it at least once a day!
Could do worse for a daily, haha!
That makes 2 of us....i see that thing everywhere..seen it in blackmans bay 2day
Iv been confused with the colour too....id say midnight blue
spotto:
3 black 32 gts-t's
1 black 32 GTR
That orange 33
White HR31 2door
All in kingston
Spotted:
Sounds like Greebo's...
Spotted many a import go past the beach while i was playing the back 9 at golf today.
FARK ME IT WAS HOT :D
the hr31 is floody.
I also see that blue/purple 33 and always on the southern outlet. must also live down kingo way.
spotted a wingless green 32 gtr in kingo today 2.
that would be me in the green GTR, Nice work on the Dyno yesterday in the GTS2
Spotted crazy Tone in his 33 heading home after work this arvo, early knock off as usual hey cobber :happy:
Spotted Nathan in his white 33 coming a couple of times in the last few hours and spotted a blue 32 GTR yesterday arvo at BP Kingo.
Anyone know who owns the black 34 GTR, obvisouly fresh to the shores cause i've seen it a couple of times now and it hasn't had plates :(
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
