Never seen it in the flesh, only in his signature (which doesn't show a huge amount). I'll take a look around on here for some higher quality pics and keep an extra sharp eye out for it out on the street. Sounds like a horrific crash with the blue 33, I had no idea... Horrible to see yet another one go to waste
Going to stop spamming and busy myself elsewhere for a while as this is hardly spotto-ing :rofl:
well empra was rolled into a brick wall and suffered quite a bit of damage, this was a few months ago though.
The front bar has a bit of damage where it looks like it's curled under the car and the bonnet looks a little bit long on the body (but I think that's just aggressive styling) as you can see in the picture. Either I'm seeing ghosts or she's back on the road with any major front end damage fixed and a patched paint job.
Pretty damned sure of the days I saw her, as I was scuttling back from work in the blistering sun attempting to look like less of a blob of sweat (being Tasmanian anything over 25 degree's is like an oven to me).
woulda been yup :) was on a cruise for a mate. what the hell was going on in cygnet??? like a bajillion people there
More than likely the redirected traffic from Margate due to the accident.
there's the cygnet folk festival (read: hippy festival). im staying with some friends - last night i went on down to huonville in the GTR and ended up in the middle of a cruise.. i was like what the hell! last thing i expected to see down here :)
there's the cygnet folk festival (read: hippy festival). im staying with some friends - last night i went on down to huonville in the GTR and ended up in the middle of a cruise.. i was like what the hell! last thing i expected to see down here :(
haha i heard there was another GTR down here over that week. every one was telling me how nice it looked.
Spotto'd Funz in Kermit and a guy (I'm assuming Mr. Untouchable?) in his dark grey/silver R33 at the round about near the fork in the road today, and a nice white series 2 R33 a bit further down the road. Attempted to get an arm out the window for a wave but my drivers side is stuck closed :(
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
