Its a GTS-X, came in from japan with the sticker and spoiler already on it. Has a few fancy things in it. Like a self adjusting rear view mirror which i need to fix, also the electronic in cab adjustable suspension still works, but only the front as it has aus spec struts in the rear.
The plan is to stick my s13 coilovers in the rear soonish to bring it back level, will eventually go s13 coils in the front, along with r33 gts-t brakes all round and a nice set of fat wheels. And also my RB30ET will be going in along with a high mount turbo. Not sure if i'll stick with the GT3082 or if i'll go with a different turbo. Also plan to put a R31 house front bumper on it, and maybe a carbon vented bonnet. Not sure. I should probably call this one money pit 2.0.
Thanks for the positive feedback fulla's.
oh and :D
nice one ditch the wing and sticker :worship:
i had to take the clagged out adjustable suspension out of my coupe to it had two great settings spongey and boat mode gave it some coilover love and it loves it now. mine doesnt have the flash mirror thingy though would love to check that out
Spotto a mint looking bayside blue r34 in Launnie yesterday :O
if its the one im thinking of i met the guy tonight, and yeah its prime!!!
he said hes had it since 05, but just had it as a weekender
    • And one last super random thought, I remember when SAUNSW had a dinner with Alan Heaphy, and another with Fred Gibson there was talk of the R32 GTR cast alloy uprights failing in racing, and one of the things Fred did when they had to add weight to the vehicle was taken the failing alloy uprights, and have them made of steel. Does anyone remember back to 1990/1991/1992 and WHAT was failing in the front hubs/uprights?
    • If you truly want to know how the original failed though, was it a factory defect possibly etc, send it off for investigation. Would probably cost a shit tonne.   The ones that you need to win lotto for, unless you have a good reason for that part to be bolt on, I'd probably roll with getting a few small stitch welds carefully put in place as an extra safety factor once everything is all torqued up tight
    • Are you sure? Because I wouldn't necessarily be. Do we even know the material they've made the new uprights from?   Looking at the fractures in the earlier pics, it does to me look like both a twisting, and levering upward action doing the damage, so you're hoping for both compression, and tension. Depending on the bolts, they can stretch (even high grade bolts will) and now you're hoping for the threads themself not to stretch, as if they do, bye bye mating surfaces holding together, hello bolts now going into shear.
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
