I have just picked up a S14 R200 diff with viscous centre and have ordered the OEM nissan shims and plan on removing the current shims and installing 1.01 mm ones (factory ones are 0.80mm) There are 2 shims in the LSD and this will take the total preload up .42mm offering a tighter than factory viscous LSD. you can install 1 shim plus the 2 already there bringing the total up to 2.40mm but you will basically have a locked diff and are risking the spider gears binding.
The LSD cost me $100 and the shims about $10 each. and anything has to be better than an open wheeling diff. I am not expecting a mechanical 2 way or anything but will be happy with anything better than current.
The Diff I have in my car at the moment has a 4.3 ratio and the diff I have just bought has a 4.08 ratio. I don't really want to pull my old diff apart and am thinking of just using the 4.08 pinion and ring gear. How much difference will there be? between the 2 ratios? I have never really understood final drive ratios.
Also can you measure nissan diff ratios from the number of teeth on the ring gear? the one I have just got has 37 teeth. I would really like to confirm it's ratio is 4.08. Can anyone in the know about ratios please comment.
Thanks!
I will post up the results as soon as it is in. I am installing it on the weekend.
I have heard some really good results and will keep you all posted.
Not sure if this helps or not but this is the guide I used when I shimmed a diff a while ago
http://www.d1nz.org.nz/forum/viewtopic.php...a84e160bbe32105
There was only 1 factory preload shim in mine though (R32).
Here' a list of shims + prices that I found from another thread.
0.80mm = 3842440f60 price = $10.12
0.85mm = 3842440f62 price = $14.67
0.90mm = 3842440f63 price = $9.97
1.01mm = 3842440f67 price = $9.79
1.05mm = 3842440f68 price = $14.40
1.10mm = 3842440f70 price = $6.37
1.20mm = 3842440f73 price = $6.37
1.30mm = 3842440f76 price = $10.89
1.40mm = 3842440f80 price = $6.37
1.49mm = 3842440f83 price = $6.37
For a tight VLSD that's not locked, I would personally got 1.2 or 1.3mm shim without the stock shim. But I dont know, I havn't tried personally, just a guess. The one I shimmed up was for a guy that wanted it locked, so I put in a 1.49mm + the stock 0.8mm.
Using the different final drive will put your speedo out as the speedo reads off the gearbox and assumes a final drive rato. If you've got the whole diff, count the number of teeth on crown and divide by the number on the pinion.
You will have 5% less acceleration but 5% higher top speed.
Edited by salad
Thanks Salad,
yep. I have pulled the centre apart and found there to be 2 preload washers
1 on the onderside of the viscous centre and one on the other sode of the spider gears carrier ( opposite ends of the housing)
I found that when I put the second shim in the whole assembly would not screw down completly leaving a 1mm gap between the 2 halfs of the pumpkin.
Did you find the same thing?
CEF11E,
Could you count the spline on your half shafts (that slide in to the viscous hub)
I have a good tight VLSD Q45 Infinity viscous hub here that I'm toying with throwing in to mine for a quick fix.
Long story short I picked up what was supposed to be a GTR diff and axles, turned out to be GTR axles but with a Q45 Infinity vlsd centre and half shafts.
The Q45 Infinity runs the same half shaft/axle 6 bolt (1x6) pattern as the GTR. Unable to tell the difference until you rip the back cover off and notice its a VLSD unit. :P
I had a hell of a time trying to get the unit back in to the housing. :S
Let me guess? blocks of wood and a hammer?
sure will count the 1/2 shaft splines today for you.
The diff I am using is a S14diff with 3x2 halfshafts so I am not sure it will be the same.
It will be fine. The 3x2 halfshafts are interchangeable with the 1x5 halfshafts. :D
yes Blocks of wood and a mini sledge hammer. :P
Thanks Salad,
I dont remember one being on the other side of the spider gears carrier, although it may have been stuck to the housing?
There was a gap when I slid the 2 parts back together, but once the screws were tightened the gaps were pretty much gone.
Hows the VLSD you shimmed holding up?
I was actually just trying to sell my old VLSD centre so I just shimmed it to sell it. Sold it to a guy on NS.com and havn't heard back from him since, so I assume it's still goin. :pwned: I can get onto him and ask him how it's goin if you want?
I shimmed it the same way as a couple of my mates did aswell, and theirs are still going after over a year of track and daily driving.
Edited by salad
Yeah, left the stock ones and added one.
I didn't realise there was one on top of the spider gears though. Guess it makes sense that there would be one there. Must've been stuck to the housing so I didn't see it.
I was mainly going off the guide I posted earlier. It said if I wanted it very solid, put 2 extra stock shims in, so extra 1.6mm, I put in an extra 1.49mm, close enough.
Edited by salad
I am still deciding what level of shimming to use.
I bought 2 1.01 shims and think I will use one of those either side. I am not after a locked diff and the centre will not screw together with 3 shims in it there is a 1mm gap.
I can not turn the centre at all by hand using the 1/2 shafts with the 2 1.1mm shims in so i presume it will be fairly tight.
I put in a 1.2mm + the std 0.8mm shim in mine and i hated for the first few weeks, as it felt like i was driving a train when turning corners with a constant "clanking" sound.
A couple of months later sound and locked feeling has worn off and still not open wheeling... Plus the car feels so much more predictable... it reminds me of when i first got the car with 64K Km on it....
Mistake i made when assembling it together was not putting in shafts before tightening crown, as splines did not line up and hence shafts would not go in all the way...
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
