New 4 door round...
Guest 382 GZV - 4 Door R33
G'day,
Just thought I'd introduce myself (after checking out SAU a bit). May have seen me round a bit - live near UQ.
After having completely broken the auto transmission in my N13 Pulsar for the 2 time in 16 months, I figured I needed something sturdier. I found nirvana at the end of Feb after waiting for over a year :)
I'll try posting a pic of my car on, it may be too big though. It's nothing flash, just the only photo on my computer atm. I wanted something I could keep for a while and since I'm already married (only 20 though) and kids may be sometime in the future, it had to be a 4 door.
Anyways, if you want, say hi when you see me and lemme know what's good and what's not with mods as I am planning on doing something year.
Steve
PS. Skidpan day was great slip; will defnitely be doing the next one :P:D :D
https://www.sau.com.au/forums/topic/15314-new-4-door-round/
Hi Steve, good to see some more 4 doors getting around :(
u might have seen me on sunday, i own the silver r32 4 door.
if u need and help or advice with mods give us a yell, my dad owns a r33 4 door so i've been down that path before :D
https://www.sau.com.au/forums/topic/15314-new-4-door-round/#findComment-312964
Mountains are mad :-) Is it true that guys drift around corners on the mountain so it's pretty slow going??
What are you getting done to your car slip?
Hey, I found driving a skyline is a bit different to driving a Pulsar. I use to have to sit flat footed everywhere round town in the pulsar. When I got the skyline I was in the habit of flattening the accelerator (had to use a fair bit of braking to keep it in check). So I was only getting 280 - 350 a tank! :-( At least it is better now...say 460 a tank. At least I can save for go-fast bits now.
:):D :D
https://www.sau.com.au/forums/topic/15314-new-4-door-round/#findComment-316267
Welcome GZV...
I have recently had my first baby... thus traded in my beloved DOHC Jap-spec VTEC Civic (15 sec quarters) for my black 4 dr manual, too. Turbo cars are certainly different in their power delivery. Civic made more and more power through the rev range - right up to 8700rpm! R33 gives a couple of BIG shoves, one at around 3000rpm and the next at 5500rpm. With the boost wound up a little to 10 psi I'm pretty sure the standard computer is overfuelling and retarding the timing - from what I've read here in the forum - causing a flat-spot btwn 4200 and 5500rpm. (Maybe MicK51 has a few ideas!) Hoping to get that sorted one day - hopefully soon - but probably when my boy goes to school (in 5 years!!!) and my wife goes back to full-time work!!! Who knows...
Will post a foto here of my 4dr in next couple of days!
Would love to do something on the track. Have taken Honda out b4 but not the 'line yet! Just for the hell of it...
iijj
(North of Bris)
https://www.sau.com.au/forums/topic/15314-new-4-door-round/#findComment-316328
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
