  • Replies 162
When you say matrix you mean interpolation.. i.e averaging surrounding cells?
Tim Possingham was/is a wizard with the Microtechs, BUT I do remember he mentioned it can be tuned for the absolute best economy but slight response does suffer. Its just a limitation of the limited load and rpm points. Interpolation can only 'guess' so good.
i ran my PFC with closed loop off for a few months (extensive work on the fuel maps however)
getting around 400k's to tank, sometimes slightly under
with it on it was consistent over 400k's to a tank
so its not the be-all and end all, but it is a good feature to have
if the fuel maps havent been tuned properly (lots of time/labour) then economy will suck without working closed loop.
so does the microtech have closed loop now ?
theres a couple of 33 pfcs on ebay and even a 34 one for 1350$
still cheap in comparison to what else is out there , just dont think about the old price a couple of months ago
That 34 PFC on Ebay is currently on its way to me now :laugh: Paid too much for it but I don't care, at least I was able to get one finally.
Maybe a little clarification might help.
The SAFC/SITC combo sits between the AFM & CAS and the standard ECU. So they modify the signals that the standard ECU receives, tricking it into using the load points on the fuel and ignition maps that give you the desired A/F ratio and ignition timing.
AFM --> SAFC --> standard ECU
CAS --> SITC --> standard ECU
The Jaycar DFA kit achieves the same thing
AFM --> DFA --> standard ECU
The DFA is obviously quite cheap (~$80 plus $70 for the Controller). SAFC’s are readily available, new and used but SITC’s are hard to find as they have been out of production for some time.
The big advantage is you can fit them yourself, set them on zero correction and then drive around just as you would if they weren’t there. Or drive to the dyno for tuning. The SAFC (& DFA) will enable you to stretch the standard AFM as far as it can go before it maxes out. The standard ECU protection stuff (knock and limp home for example) still function.
These are easy to tune, 20 minutes max on a dyno for SAFC/DFA, less than that for the SITC. They have been around for years, so plenty of tuners have experience, even if they don’t, it only takes a few minutes to get familiar
They don’t disable the 180 kph speed limiter, so if you are doing any track work you will need something like a HKS SLD (Speed Limit Defeater/Defender)
The EManage sits between the standard ECU and injectors and the coil ignitors. So it modifies the signals that the standard ECU sends, using the load points on the EManage fuel and ignition maps to give you the desired A/F ratio and ignition timing.
Standard ECU --> EManage --> Injectors
Standard ECU --> Emanage --> Ignitors
The main problems with EManage in the past was its inability to run R33/34 ignitors. A few guys seem to have had success lately so maybe the problem has been overcome. If it has, then they are not a bad choice. No SLD required as the EManage intercepts the speed signal before it gets to the ECU. Since the EManage controls the spark there is no ignition retard on gear changes in autos, so the gear changes are a bit harsher and the gearbox will wear out a little bit faster. The ignition cut on full throttle gear changes seems to still work (limited testing) so it isn't as bad as using an aftermarket ECU with an auto.
The HKS FCon in its various generations is pretty much like an EManage. Except the tuning software is only available to HKS approved (royalty paying) workshops. Last time I checked that was only one in Australia, BD4’s in Sydney
In theory the EManage should enable you to drive the car to the dyno, but this hasn’t been the case in many instances. They are not as popular, so not as much experience out their in tuner land. Be careful of the add ons, the base price may seem attractive, but the options soon add up.
That covers the major piggy backs, ECU observations another day.
:blink: cheers :P
Apexi Power FC has to be the best value for money ECU for Skylines if you can get your hands on one. However it too has limitations due to MAF/AFM prerequesit. A MAP sensor based ECU will handle higher power levels with more accuracy from what i have read.
I personally dont like the idea of an interceptor type aka piggy back systems cause your only fudging the signals that the ECU recieves.
So for stand-alone ECU's my research has lead me to the conclusion that the following would be my order of preference due to cost Vs value:
1. Apexi PFC (Plug & Play) - AFM
2. Haltech E11v2 (Plug & Play) - MAP Sensor
3. EMS 8860 (Wire in) - MAP Sensor
4. Autronic (Plug & Play) - MAP Sensor
5. Motech (Wire in) - MAP Sensor
Cheers
this is inaccurate, covered in the powerfc faq in great detail
d jetro vs l jetro for both powerfc and other mainstream ecu's
you should read it
its not a limitation, in fact map gives you less load points making it having less accuracy
Yea your right with that paul, i heard that MAP sensor based ECU usually have poorer fuel economy compared to AFM based ECU's due to more load points...
Thanks for clearing that up!
Cheers
Fcon pro v for the win!
still am yet to get mine tuned but when i do its going to be an animal and my fuel is going to last a wee bit longer one would think!
will get it over to bd4's soon
you should read it
is this only really comparing power fc d jetro to l jetro tho?
well the topic is around the powerfc as its in the powerfc faq.
but the same principal of ljetro (airflow meter) vs djetro (map sensor) still applies. very interesting read. the only reason you woud have poorer fuel economy would be the tune and the time spent on it.
there is no reason both cannot have the same fuel economy and power from either afm or map sensor. map sensor will probably take longer to tune and run sinle axis style once target boost is reached (generalisation)
There's a guy somewhere down under.
Bikirom- Made for SR's, KA's, VG's etc.
It opens up your stock ECU so you can do anything the computer does.
Currently it doesn't work for the RB's, but it we send him some emails maybe he'll be interested in adapting his product for us.
www.Bikirom.com
no its not but as you said it costs $$$ to tune for cruizing and modify that end of the map which most people dont do , particularly microtech buyers down the bottom end of the scale
and with closed loop the ecu is automatically tuning itself for optimum economy
so its a win situation
defiently not the end of everything , particularly in race type setups where its mostly WOT but its still a good thing to have and if microtechs had it 90% of the cars runing them would get better fuel usage
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
