Dont flame me .. I just asked a audio expert .. An installer not a seller
Dynamatt doesnt do much .. It reduces slight vibration but cheaper options also work well .. In his opinion he said its not worth it .. Oh this was in the boot .. in the doors hes all for it .. but still says its better just to do the surrounds to reduce weight ..
Out of interest, what were the cheaper options he mentioned?
well one was expanding foam (rookie told me that one and no way I would do it ..)
He explained padding foam would work if its hard packed and making sure everything is tight... He told me cheaper version will do just as good but we had the system running (boot closed) I grabbed the spoiler to shut the thing up and he said thats what dynamat will do.. It was a noticable difference but not $100-200 worth of it .. even tho the system it worth 50 times that much he still didnt feel you would hear the effects in the cabin ..
Edited by DECIM8
Dynamat is not made to reduce rattles, unless you use the one thats specifically designed to reduce rattles.
I would tell your installer mate to go back to school and have a few more lessons in dynamat and reduction of road noise.
Also EXPANDER FOAM do you even begin to understand the catastrophis results EXPANDER FOAM will have on your panels when it starts expanding? Its been known to warp the cars panels.
George
Edited by Adelaideprosound
Im just preachin his word... Obviously he'd know something.. hes been in the business for 10 yrs so I dont know..
Everyones got a opinion so i guess thats his .. not that I dont believe u either but id like to hear before I buy..
One more thing I doubt hes studied it hes just used it and felt it was worth less..
Well i use it and have demonstrated the differences time and time again. So i dont mean to sound arrogant but perhaps he was using it to STOP RATTLES not to REDUCE ROAD NOISE.
Dynamat is proven all over the world as being worth its weight in gold, and is being used by every single high end installation expert and SQ nut.
Lets agree to disagree, but when applied correctly and utilised properly Dynamat does a LOT.
How much would it cost to do a DECENT sound deadening job (diy of course)?
I knwo that everyone's decent has a different meaning, but lets just say such that the car becomes significantly quieter so that you can actually hear it. Not like a 1db drop that can only be detected using a db metre.
Would that just be doing both doors?
possibly parts of the boot/rear quarters?
underneath the rear seat?
rear seat sides?
floor?
roof?
behind dash?
$300ish for dynamat bulk pack, dynaxorb and a bottle of prepsol.
the rest is elbow grease.
a bulk pack should do both doors and leave you enough to get stuck into the boot and some under the rear seats if you haven't had enough fun yet.
alternatively, phone a friend and you could probably do the doors on two cars (with more dynaxorb for the other car) and see how it sounds.
if you want to go further at a later date then save up and buy another pack of dynamat and a few beers.
best way :laugh:
or work it on this: 88/hr average 3-4 hours to do a car and a box of dmat.
Just to respond I dont disagree with u .. from the info i got it was exactly as you say worth its weight in gold. But hey I might give that gear a go neways with a 40kg enclosure in the boot aint like 10kg is gonna hurt my ride any more ..
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
