hey guys havnt posted much on here for a while just been busy however my car is ready just went to see it today i got fitted:
gt30 int gate
bosch 044 fuel pump
ems stinger
nismo 740cc injectors
quite happy with the results on low boost 15 psi it made 350hp and on 18 psi it made 380hp so im very happy considering its aint gate turbo and standard internals il be sure to bring it on the next cruise
cheers sam
https://www.sau.com.au/forums/topic/154095-car-finaly-back/
  • Replies 85
Posted Images
havnt driven it yet lol only watched it on the dyno going to pick it up tommorow he told me that it may light up in 3rd and 4th lol but i wil be very cautious as im still on my p's il save it for the track and the ems it self comes witha afm
https://www.sau.com.au/forums/topic/154095-car-finaly-back/#findComment-2865941
who did the tuning mate? thats awesome power. i have a GT30R + ext gate, 740cc injectors, bosch pump and Power FC and I hoping for the same figures once tuned.
you've had half of that gear for ages now!!! Get a move on and install would you!!!!
https://www.sau.com.au/forums/topic/154095-car-finaly-back/#findComment-2866188
haha, its all installed! has been on the dyno but the BRAND NEW AFM i bought was f*cked, just waiting a replacement now. dont worry Liz, u will be the first to know!
https://www.sau.com.au/forums/topic/154095-car-finaly-back/#findComment-2866193
haha no because i wasnt expecting this kind of power however i wont be driving it with this power and the car is only gone be driven on weekends il drive it on lowboost will crank it up on the odd occasion and i dont think there smuch of a point of a rebuild witha int gate turbo so yea not sure whats next i wanna keep it as is tho for a while
https://www.sau.com.au/forums/topic/154095-car-finaly-back/#findComment-2866247
haha cheers guys and ovaboost did all the work and tuning, highly recomend them + he is extremely good at tuning with ems stingers il be sure to bring it out on the next cruise whenever that is however ithink i need to look into getting sum fatter tyres now not sure if 235's wil be enough
https://www.sau.com.au/forums/topic/154095-car-finaly-back/#findComment-2867452
yea wish i hada known dont think my dumb rims can take up to that fat think max i can go is either 245 or 255 .. might hav to get slicks lol
go the semi slicks :wave: You will have a lot of interesting times in the wet hehe
https://www.sau.com.au/forums/topic/154095-car-finaly-back/#findComment-2867683
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
