  • Replies 701
Posted Images
Liz - I wasn't holding back, I had a dud entry to the straight, and the car had been miss firing all day (lambda sensor died, couldn't tune it), so I was never gonna catch you, but you were quick through the kink, I just didn;t expect you to slow down so much for turn 1 - I didn't want to hit you, and I was aiming at turn one at the fastest possible speed - to avoid a massive lock up, and or a massive accident, I aimed for the greenery - which turned kitty litter brown very quickly... and I couldn't drive it through it, it was soo soft by then
Dunc - I killed it, but we think turbo seal - We won't touch it til later in the week, we need a break from working on it, dad spent all last week getting it ready for sunday
Cheers
Matt
PS - Any pics of my car on the track??
dont worry Duncan i wont be running 2 bar next time....but will get the better clamps and maybe the silicon...
Is any other newbie lying in bed thinking about the next track day and how they can improve their times?
bloody cant sleep
Man so pissed missed this day... reading all this makes me wanna cry!!
Liz - Dude!!! I read you were down into the 1:15's without semis!!! Far out.... the taxi better get some more mods to keep up!! AWESOME EFFORT!!!
Bring on next track day... maybe it will be me buying you a case of beer!!
bloody cant sleep
Absolutely. Ive been thinking about the next day and how i could handle a few corners better without spinning 65 times around! how did you go on your timings this time around anthony?
I love spining I got it down to a fine art!
Im looking foward to the next track day and i tell you i will definateley have semis next time that was the only thing letting me down on the weekend was my tires my brakes were fine i was out braking most the cars even the ones that were faster so definatly need better tyres next time. Anybody got and other photos of my gun grey 32 the one with all the advertising on it any on the track would be great.
Traman i dont know if anyone timed me....semi slicks are definitely required...my 245's all round are good in the wet but average on a track....plus i need more driving experience.....when is the next track day?
Great day, heaps of track time, wet and dry conditions and nice cold temps for the tubos.
My only problem with the cold temps was that by the time my tyres were up to temp my brakes were overheating, (dam standard brakes!)
Thanks to the organisers, well done.
you drive your car well...get good pads on board.
It was an awesome day - A huge thank you to the organisers/volunteers.
I have an interesting helmet cam shot of someone getting a bit loose in front. I'll find an editing program and cut it down small enough for youtube. Then the driver can put their hand up :nyaanyaa: and say who it was hehe.
Thanks again for a great day... I wish I didn't have to leave early.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
