  • Replies 701
Posted Images
Liz - I wasn't holding back, I had a dud entry to the straight, and the car had been miss firing all day (lambda sensor died, couldn't tune it), so I was never gonna catch you, but you were quick through the kink, I just didn;t expect you to slow down so much for turn 1 - I didn't want to hit you, and I was aiming at turn one at the fastest possible speed - to avoid a massive lock up, and or a massive accident, I aimed for the greenery - which turned kitty litter brown very quickly... and I couldn't drive it through it, it was soo soft by then
Dunc - I killed it, but we think turbo seal - We won't touch it til later in the week, we need a break from working on it, dad spent all last week getting it ready for sunday
Cheers
Matt
PS - Any pics of my car on the track??
dont worry Duncan i wont be running 2 bar next time....but will get the better clamps and maybe the silicon...
Is any other newbie lying in bed thinking about the next track day and how they can improve their times?
bloody cant sleep
Man so pissed missed this day... reading all this makes me wanna cry!!
Liz - Dude!!! I read you were down into the 1:15's without semis!!! Far out.... the taxi better get some more mods to keep up!! AWESOME EFFORT!!!
Bring on next track day... maybe it will be me buying you a case of beer!!
bloody cant sleep
Absolutely. Ive been thinking about the next day and how i could handle a few corners better without spinning 65 times around! how did you go on your timings this time around anthony?
I love spining I got it down to a fine art!
Im looking foward to the next track day and i tell you i will definateley have semis next time that was the only thing letting me down on the weekend was my tires my brakes were fine i was out braking most the cars even the ones that were faster so definatly need better tyres next time. Anybody got and other photos of my gun grey 32 the one with all the advertising on it any on the track would be great.
Traman i dont know if anyone timed me....semi slicks are definitely required...my 245's all round are good in the wet but average on a track....plus i need more driving experience.....when is the next track day?
Great day, heaps of track time, wet and dry conditions and nice cold temps for the tubos.
My only problem with the cold temps was that by the time my tyres were up to temp my brakes were overheating, (dam standard brakes!)
Thanks to the organisers, well done.
you drive your car well...get good pads on board.
It was an awesome day - A huge thank you to the organisers/volunteers.
I have an interesting helmet cam shot of someone getting a bit loose in front. I'll find an editing program and cut it down small enough for youtube. Then the driver can put their hand up :nyaanyaa: and say who it was hehe.
Thanks again for a great day... I wish I didn't have to leave early.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
