Hey im chasing a new exhaust manifold gasket for rb20det.
Tried the local shops we have here but no good (only sell full vrs kit).
Can anyone let me know if anywhere sells them on their own and how much they go for etc.
Thanks.
Yeah first thought but our nissan dealer here cant get in anything im not sure why, my guess is that they cant be bothered with any import parts.
Ill give them a call now to check.
Anyone know if Autobarn sell them? We don't have one here but ive dealth with them posting stuff before.
i get most of my parts from Nissan too, i genially find there cheaper than the aftermarket stuff. if your locale dealer won't help you, just go to another, I'm shore there's more than one in your area.....
I've used Lintott?? in Sydney, very knowledgeable guy there I think his name was Jay. Lintott are a Nissan agent and they are uber cool, they were bringing in genuine Skyline parts even before the rest of the Nissan network caught on.
Try here:
http://www.lincorp.com.au/aboutus.htm
Try here:
That's Parramatta Nissan mate. The club has a discount with them.
Also they will post stuff to you if you ask.
And, Justjap will sell them and post them to you no probs.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
