It does if you put an Rb20/25/30 spiggot bearing in.
Darrens (Bl4ck32) RB30 had a flywheel attached as it was from a manual car.
But to his suprise it still had the automatic spiggot in there.
The Auto spiggot hangs 1/4 out of the crank. The Manual spiggot sits all the way in and you can only just get a finger in there.
The Auto you can almost fit a thumb in it.
I posted pics a while back.
Unsure if it was in another thread or in the RB30 thread.
I've been getting a little bit of reversion occuring with the stock rb20t turbo and std. N/A cam specs.
I've advanced the timing quite a bit 25degree's to help smooth it out.
Now I can only ever so slightly feel the bog down only under certian conditions.
Its going on the dyno Friday for a tune so it will be interesting to see if it gets rid of that afm cut I'm getting at around 10psi. :P
AFR's are fairly rich dipping in to the 10's and it only gets richer as boost increases.
I have a question.
I'm worried about running the engine in with all the aftermarket parts i'll be using with a power fc on a standard rb25 tune.
Would it be better to run the engine in with the standard cams and injectors and install the pon cams and 740cc injectors later. (valve springs will be already installed.
Hi Alf, I would stick it all in, that's what I do. It is so much easier to do on the engine stand than once it is installed in the car. I simply take 700 cc vs 370 cc out of fhe master fuel correction on the PFC Commander (about 45%). Remember to do that every time you turn off the engine as the Power FC does not retain master corrections.
Hope that helps:cheers:
Can you not do this in a more permanent way?.. seems odd to do it every time you turn the car off??
I dont believe there is anyway in the PFC Hand Controller to do this. We looked for ages for this option and the only way i could take a certain % of fuel out of the system (50 psi base pressure in fuel) was to go into the INJ map and take out 15 press's on EVERY load point which took me about 2 hours :D
I dont believe there is anyway in the PFC Hand Controller to do this.  We looked for ages for this option and the only way i could take a certain % of fuel out of the system (50 psi base pressure in fuel) was to go into the INJ map and take out 15 press's on EVERY load point which took me about 2 hours  ;)
It only takes a few seconds to change the master correction, until I get to do a proper tune, it is the best way I have found. Going though the maps and changing 400 load points by the same amount is a waste of time as you have to tune it properly soon anyway. Guessing a single % for the whole rpm and load range is not a good idea. If you are going to carry out minor upgrades often, then you should look at a Datalogit, it's very simple then.
Thanks for the advice. I should be able to get the car running with the master correction on the hand controller and then get it down to a dyno with a datalogit for the actual tune ;)
You don't need to do the tensioner like this also. I think 2 tensioners in the stock position would be fine.
I like the second (high) tensioner mount, same as this. Personally I think the tensioners get too close together when they are both mounted low and the teeth face each other. Any slacknes in the belt or a bit of whip and the opposing teeth will rip each other to pieces as they are travelling in opposite directions at big RPM.
I see your point..
I was thinking of the OS RB30, they have the low mounted tensioners, but then again, they have a different sized belt also. ;)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
