phantom
when the block are bored we always make sure the run speed is low ie the bore tool moves slowly up and down the cylinder giving you a finely hatched pattern about roughly 25-35 degrees to the horizon if you where looking straight at the bore from inside. As my engine machinist has now aquirred a torque plate honer i will be using that from now on although the difference is minute its still ensuring the best possible result.
discopotato03
with standard rod and pistons you can run the standard headgasket and using the headgasket on foges with my experiece with arias will give you around 8.6:1 comperssion using the hightops with standard rods, using the flat tops i believe its below 8 around 7.4:1. However the eagle rods being chev arent actually the correct length they are 6 inch not 5.92 that standard rods are and the sit above the deck height enough that you will need at least a 1.2mm headgast to acheive a squish and avoid valve isssue when running bigger camshafts. All this info is based on the 26head but its pretty much the same if you are using a 25 head, but the 20 head is different, correct me if im wrong i believe the cc of the rb20 head is 63cc and the rb26 is 66cc so it changes it all right there.
phantom
discopotato03
Who is your machinist, does someone in Canberra have a torque plate now ?
My appoligies for bringing up old stuff but I couldnt find any photos as most of the pics dont work anymore in older posts.
My engine builder hasnt seen my head yet but he tells me that the rb25det head rear passenger's side water jacket sits out past the block, the na rb25 head doesnt. I'm still scratching my head how he came to that conclusion when my head doesn't have this problem.
Now all kinds of thoughts are going through my head atm, do I have an NA head or are there variances in the 25 turbo heads, VVT is an obvious one (mines VVT) then I go on thinking do I have an na inlet manifold,cams and valve springs...:confused:
The pic below is my bare head, the orange arrow is where i've been told the problem is.
The complete top end came off a 33 gtst so I would assume it would be a turbo head.
In the past replies SK and Joel have used na heads, what are the characteristics of the na cams on the new engine? any problems with reversion etc....
Cause if I'm stuck with na valve springs etc..:slap: it maybe time for tomei pon cams and stiffer springs.
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
