The std head gasket is fine. Generally ppls use them and do the O-ring thing.
If I were to do it I would most probably go a Tomei Headgasket and use its oil restrictors, slap them in the block while I'm at it.
If this Cometic headgasketever starts seeping water thats the route I will go.
Whats the final power goals.... Generally the only reason ppls use a different headgasket or oring setup is under high combustion pressures (i.e lots of boost and lots of power) its possible to squeeze some of that combustion pressure past the gasket and in to the water gallerys.
ok i musn't be able to read properly or something
but after reading the DIY for probably the 30th time
i realised that it clearly states the RB20DET valve springs fit the RB25DE head
man how stupid am i lol
even on the box of tomei RB20DET valve springs it says RB25DE as well
thank god i finally worked it out :P
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
