Just had the VL on the dyno and thought i'd post my results. A bit of background......
Stock RB30 block
Stock R33 RB25DE head, VCT hooked up.
R33 RB25DE oil pump
GT3040, 0.82 rear
RB20DET ex. manifold
550cc mazda 20B injectors
600x300 cooler
Bosch 044 pump
258rwkw on 13psi
800ish Nm (can't remember exactly)
Don't have a dyno printout ATM as the dyno keyboard shat itself, but he saved it and i should see it sometime this week.
I honestly didn't pay to much attention to the RPM/power relationship while it was on the dyno. My eyes were glued to the power figure! Like i said, the graph wasn't able to be printed at the time, so i'll have to wait till he e-mails it through.
Wastegate is an external 48mm progate mounted on a custom adapter between manifold and turbo.
ECU is a Haltech E11v2 with a 2 bar MAP sensor. The boost cut is set at 2 bar absolute (obviously) and even though the wastegate solenoid is set to provide 13psi, it occasionally spikes and hits the boost cut. Hopefully closed loop control will sort this out.
quick question guys.
If i were to do the RB30 upgrade on my RB20 equipped R31, would i be able to use the microtech i already have in it on the RB30? Also, would everything else wire up as is? or will i have to go through a huge auto electrical drama?
Also, what would redline be if you get the RB30 crank propperly prepped and balanced?
Im using a microtech with the stock RB20det loom, no problems, just use the stock RB20 sensors.
Hey,
Just got the power tune done and very happy with the results.
The car is so responsive it's not funny and I _______ mean it !
We're all quite surprised with the power output and especially the turbo.
Having the high-flowed stock turbo was always questionable, but even more than before the conversion, it spools up so quick and holds 18 psi efficiently.
I've been considering a GT35/40 onto the stock manifold but I'm now reluctant to change anything given the instant boost.
The accelleration is just exhilarating and I _______ mean it !
Tuned to 15 psi due to stock injectors we got 294 rwkw / 508 fwhp.
Next service, will go for Sard 550's and push the turbo as hard as possible.
Nengun will deliver for $674.00 !, bugger high flowed injectors..
Dyno graph posted in the RB30 results.
God bless Nissan and everyone who's been part of this conversion.
Edited by conan7772
15psi = 294rwkw yet with 3250rpm full spool?
Almost sounds too good to be true, if thats really the case stick with it as a GT35R will be laggier and will require more boost to make that power.
What fuel are you running?
Turbo specs?
What fuel pressure are you running? :O
could be running bigger cams to help bring down the boost level, dont really know specs of the engine..
im getting 294 rwkw with teh std RB25 @ 18psi, but with tomei pon cams..
maybe some more details on the motor will help make that tune results make more sense.
Thats good power also.
What spec cams, and what other parts on your motor (aftermarket plenum, exh manifold, etc?)
plazma man plenum, custom highmount setup, HKS GT3040 1.12 rear housing. tomei pon cams 256 /8.5 power FC and 550cc sards, sard 1:1 fpr, Z32 afm
laggy now, but will be better suited once the rb30det is completed. full boost of 18psi at 4700rpm.
wheres the std rb25??
what did you mean by? -
std bottom end was what i refering to...
main thing was with Sky30's post refering to his 35/40 cracking 300kw @ 18-19 psi... and thats a rb30det.
there are things that can help reduce the psi required for certain power levels..
Edited by Craved
Read again mate..
"Having the high-flowed stock turbo was always questionable, but even more than before the conversion, it spools up so quick and holds 18 psi efficiently"
He said he got 300kw at 18psi on the high-flowed stock turbo ...
Stock hi-flow making near 300rwkw on 15psi............. are you sure?
My 35/40 only cracked 300rwkw on 18-19psi.
It looks like stock housings to me.
The dealer I bought it from said it was a T3/T4 Hybrid.
I don't know for sure. See pics...
It was bored out to the max on the compressor housing. Bugger all meat left on the intake.
Also, before I blew up the RB25DET with this turbo, it had 247 kw.
That dyno graph is also posted.
Read again mate..
No
294 kw at 15.2 psi
Power graph and pressure graph was the same test
Yeah, that looks very similar to the hi-flow i had on mine, but i only made 235rkw on 17psi with similar mods.
Have you had yours on a dynodynamics dyno?, be interesting to see the difference compared to the dyno you used.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
