Lets see what r33_racers failure was caused by before we go jumping the gun.
True, it may not even be that.
But while on the subject, does anyone run any 'engine kill' devices that detect low oil pressure and cut ignition to help save the motor? Is there a separate device like this available? A light on the dash doesn't give much time to react when at high revs, but perhaps a sensor to trigger ignition kill would be the go...
I've thought about a warning buzzer, not sure if killing ignition is the way to go, probably just better off with a buzzer so you can drop it in neutral asap. Providing you don't forget about the buzzer, it goes off and you think wtf is that, by the time you remember its too late anyway. :laugh:
Kill ignition and it may lock the rears mid corner or something silly.
I've thought about a warning buzzer, not sure if killing ignition is the way to go, probably just better off with a buzzer so you can drop it in neutral asap. Providing you don't forget about the buzzer, it goes off and you think wtf is that, by the time you remember its too late anyway. :P
mate runs an engine kill switch like the one suggested on his sprint car, with over $60K in the engine, as soon as the oil pressure drops, it cuts everything.
with our cars it might ne a little harder than the carbied V8.. as you have to bypass any chance of a turbo timer working etc, then power steering and where you are.
but i am DEFINATELY going to run a switch to a specific light (autometer pen light for example) that will be direct line of sight. might not save the rebuild, but you wont go seizing anything.
yeh i think motecs and autronics have that feature built in, if something goes over a preset warning value it shuts off the engine completely to save it from harm. I know alot of sprint car racers and even circuit racers have a kill switch hooked inline to the oil pressure switch which craved is talking about so it kills the engine if pressure drops to nothing. I think we wish we had that now haha >_<
Well my motor is nearly ready to go back in my car so hopefully thursday/friday the rb30det will be out and getting stripped down....we found a strip of steel/tin in the oil, looks like its from a bearing... :P
Oh also cubes...things we would do differently... Well our tuner wants us to run a flat 8:1CR. Id like to run 9:1, but they like it lower to help keep the knock down, so can run more timing and boost. Will definetely do all the oil control mods that SK listed properly, instead of letting my old man half arse them cause he thinks he knows better haha, umm defintealy run conrods with oil squirters and thats about it so far that i can think of. Will probably come up with more as we put it back together.
Edited by r33_racer
quickie -
what engine sealant did you guys use on the replacement whelsh plugs .. i have a black sensor safe engine sealer i used on my bike, would this suffice?
or something like a tri bond sealer be best?
Edited by Craved
Just fitted front facing plenum, what a nitemare, even check out my new clutch master cylinder to compensate for plenum size :no:, now bonnet does close :), all thats left to do is the final wiring for injectors, z32 and apexi ebc then ill crank 20psi and see what she can push at all 4 wheels!
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
