hi guys i have these pistons
AP340754 Arias - Arias Forged Pistons Rb30 Non-turbo 86.5mm Bore Supplied With Rings
how good are they for this conversion???
what comp ration would it give with 1.5mm head gasket and rb25 vvt head?? and the block has been faced if that makes a big diff (not sure how much tho)
the non-turbo pistons are better for this conversion yee? or is that just the standard non-turbo pistons which are better??
whats teh differance in strength between the turbo and non turbo pistons?
any help yet guys???
could it be that gearbox was not properly installed, or as rb30 crank end was machined to have better grip for n1 oil pump drive that something was changed causing gearbox not to sit properly and making crank to be pushed against block hence causing crank central thrust bearing to snap...
maybe check the end float on the crank. if there was too much end float or the crank was able to move back and forth along its axis for some other reason it would do so when the clutch was manipulated. if the crank moves far enough it will shift the bearings and there goes your oil pressure.
IF the clutch and stalling are really related rather than seeming to be that way, it could be that when the clutch is depressed it moves the clutch and flywheel - and crank if there's enough float - so far that the side loading on the pistons creates enough friction to stall the car at idle.
this suggestion could be really wide of the mark but it's the best one i can think of.
Timing belt setup: I picked up a Dayco 94830 belt today, 149 teeth in the 8mm pitch we need. Fits a treat, 11mm between the teeth with the 2 tensioner bearings in the low low setup. Still clears the lower cover, but only just... nothin a quick massage with the gentle persuader didnt fix, now theres heaps of clearance (5mm ish)
All the timing marks line up perfectly. Belt cost $35.00 + $15.00 to get it here (direct from Dayco through Coventry) Hope this helps.
Edited by Godzilla33
I have a problem for rb30 experts: I put rebuilt rb30/25 in my r33. I found out just after 1500km that car was stalling whenever the clutch pedal is pressed and was loosing oil pressure and short after oil pressure lamp was turning on and after some checks oil pressure to the head was zero. The engine was pulled apart and we found out that central thrust bearing in the middle of crankshaft has grinded one sidewall and snapped that side off completely blocking oil flow...what could cause this? Bear in mind that car has all new parts weisco forged pistons, rb30 rods, race bearings and done only 1500km?
thanks
Too much crankshaft end float, happens all the time.
:( cheers :(
nice work
She lives...the new motor fired up just fine this morning...no major problems yet lol. The dry sump system seems to be working fine...no leaks and the oil pressure is pretty well spot on...Only real issue is the heat now, with no clutch fan cause of the dry sump setup, were running twin thermos and they dont push anywhere near as much air. Ill have to get some photos in here sometime soon too.
Nice.. :miner:
What size thermo's are you running?
I've ran 2 x 12" thermo's and I found the same, they didn't push enough air. HOWEVER they were mounted directly on the radiator and not on a shroud like they should have been.
As for what fan to run.. Have you considered a set of EL/EF thermo's? 'Apparently' people have had no issues with overheating when running those.
Im pretty sure they are 12" also. Ive got a pretty good feeling its going to need a set of larger twins.
Funny you should mention EL...my brother was just changing his wheel bearings in his falcon. Maybe he wont notice it missing hey lol.
get em while they're hot...
congrats on getting the beast to run.
Hi Cubes , you say the EL fans fit between the A/C condenser and the radiator so in front and push fans so to speak ? I'd be interested to see pics as well . I can't help thinking fans behind the radiator would work better because in a propper shroud they can draw air from the total core area rather than pushing from the front and only over as much area as the fan/s themselves .
Incidently I came across a radiator and twin fan assembly from a Maxima (can't remember 2.4 or 3.0 L) . It looked sort of similar to an R32 GTR rad and a good relatively slim set of fans in its shroud .
I have some theories on cooling strategies but a O/T here , over to FI .
Cheers A .
I have found that a large single fan (Davies Craig) moves more air than twins.
:P cheers :D
I'm not sure if I'm really sold on elec fan/s in road cars (RWD) , I think its a flawed system that lets things get fairly hot before intervening and then dumps a lot of heat into the engine bay . At least with an engine driven fan its the thermostat regulating the coolant temperature (assumes the rad and fan can cope) and its not an on/off thing over a set heat range . OEM conditions where manufacturers like things hotter than I do it seems to cope somehow .
Cheers A .
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
