John, nothing in particular as far as the actual intended compression ratios. Build it for what you want to get from it. Easier to drive more average power and more responsive but less peak power go hi comp, dyno queen go low comp with peaky massive turbo :)
Mark (Scooby) that should be decent, but my 26 made 260 on the stock computer. Go back for refund or more power. :huh: Good luck after run in.
Steve the cams and I understand crank angle sensor are different but all else is the same. I see you are racing at the "Bank". Let us know next time you run and I'll round up the boys from the Switch to come watch and ponder just why anyone would be so silly with a 120 :)
In for sure Geoff, Havnt seen that 120 ynot out their to date. Should be an interesting toy.
On the oil pump issue, I went the Jun not for the High volume flow but simply because it is touted as a stronger more reliable pump than the N1. Also did the collar deal as extra insurance.
Steve the cams and I understand crank angle sensor are different but all else is the same. I see you are racing at the "Bank". Let us know next time you run and I'll round up the boys from the Switch to come watch and ponder just why anyone would be so silly with a 120 :huh:
AHAHAHA I sure will Geoff, and thanks... I think my mate is crazy fitting a 2JZ into a HR Holden and expecting to come away from Summernats in one piece.
OK here's a question for the airflow gurus, Geoff that means you. :nyaanyaa:
The 26/30 will not allow use of the standard airbox in the R32 GTR easily. Obvious choice is to use pods but extra height of the RB30 makes it quite difficult to accomodate pods with any kind of meaningful airbox.
I'm thinking of feeding both AFMs by having them draw air from the back of one big arse pod filter, which could be accomodated by cutting a hole in the area immediately below the airbox.
The filter area would be ample, and construction of the airbox would be relatively easy. If you look on the SSS Automotive website you'll see that their blue Improved Production car runs this type of system.
Any thoughts / ideas on this approach?
Edited by Scooby
I use that location for my air filter but there are problems.
When it rains or the road is wet the spray can be taken up, and that sends the AFMs into error as the ECU thinks they are maxing out. The right thing to do then is box it correctly to remove the spray from the NSF tyre from the problem. I'm yet to examine the effects from following closely a car putting up serious spray.
Also the location is very dirty due to the tyre proximity.
Due to the plastic wheel arch guard I'm not sure what the problem would be from NSF tyre? I can see that on the 32 GTR there would be an issue with spray coming in through the vent in the front bar but I'd counter that by making a shield.
Any thoughts on feeding the two AFMs from one big filter?
No problem with that at all. Unless there is a serious restriction on either intake path the action of the turbos will pretty much equalise intake, as well the afm signals are averaged in the PFC.
That guard liner is about as secure as a leaf in a hurricane. Both mine on the track car ripped out at about 200kmh.
Thanks Geoff
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
