HI all
Joel WROTE
There is an issue.. Apparently the RB oil pumps have a different size gear i.e NA and ET pumps have a different size gear how is the over come?
looking at the oil pumps the diffrence is in the width of the gear ,I will use the oil pump from my 25t as the gear is considerably wider and as such will pump more oil / flow.
have got oil squirters installed ,what a mission!!!, the Rb30 block has only 3-4mm metal in the casting before you enter the oil gallery (the 25t block has over 10mm).Ended up having to tap out to 3/8 bspt thread and installed the squirters into brass plugs,height of sqirters is a real issue as the crank has minimal clearance to the block,alot of mucking around I hope it is worth it.
Mayby someone can shed some light on the effectivness of the oil squirter install,I suspect that unless its a high boost+high rev drag motor the oil squirters are not really necessary (they are painfull to install).
Motor is about 1/3 reasembled ,im off to carry on.
cheers
Well basically I image it is why the RB25's and RB20's are able to make so much power before having forged pistons fitted.
For example the VL Turbo isn't able to make 260rwkw on standard pistons. The ol' VL Turbo's have many story's of melting pistons.
Originally posted by 25t
HI all
cheers
Yep 25t,
i was looking into the oil pumps to see if there was some size diffrences between all the RB motors and there is.
The difference is the gear width:
RB30E - 10.8mm wide
RB30ET - 13.4mm wide
RB26DETT - haven't measured, but looks like about 15mm wide or so to the eye.
Now, this wasnt measured by me. But from this we can accuratly say that running a RB26 Oil pump wouldnt hurt. Also i think the water pumps are diffrent also. (slightly) I will take a look tonight once i get the package. (RB26DETT oil & water pump)
Trev,
Doh...
I've got a series 1 calais. Do u think i would be better just getting a turbo block or a series 2 block?
On another note...Where you saying that the standard rb30 rods and pistons and suitable for this conversion? I know they are probably not recommended but what sorta power do u think they could withstand?
Cheers
The crank & rods are all the same in the NA and turbo motors.
Gotta luv nissan :)
Have a look on previous pages it states how much power/torque the standard rods can handle.
Don't get a turbo block.. Why? Its the same as a NA block with lower comp pistons.
A quick question, how much machine has to be done to make the rb20 head fit a rb30 block as I want the standard look with less turbo lag, stacks of torque and around 200kw at the treads.
I already have a spare rb20 det thats why i'm asking and I can get the machining for free.
Hi Rowdyr32, RB20 head won't fit RB30 block, bore size is different (78 mm versus 86 mm). RB25 and RB26 are 86 mm like RB30 so you can use a RB25DE or RB25DET or RB26DETT head on RB30 block.
Doing an RB30/RB25 hybrid for 200 rwkw would be a waste of time and money. You can easily get 200 rwkw out of an RB20DET and still have a broad power band, you just have to tune it right and select the right turbo and support systems. Check the posts, there is plenty of info on how to do it.
Hope that helps
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
