Not sure what the charge is to grind the crank snout and fit a collar is - as I had mine built up and machined and that was approx $250.
Grinding is around $150 ish
Nitriding is around $350 ish as the crank has to be ground, nitrided and then reground to size.
Those prices are ball park figures.
Ring and ask for Dave.
Edited by Spoolup
Just out of curiosity what would be involved in fitting an RB25/30 to a 180sx???
A rough price estimate would be great too if possible...
Thanks.
How are we meant to know... This is SAU. :down:
Head down the local performance workshop and quiz them. :P
Ok :) lol
I just thought someone on here may have done it before.
As far as the conversion though would you say it would be identical to an RB25 conversion ie. same crossmember, mounts etc...?
ps. I have owned Skylines before and realise that people on SAU have a lot of knowledge and experience with RB engines which is why I asked here, I wasn't trying to upset anyone and if I have I apologise.
Ok :) lol
look into the rb25/20 conversions and check heights .. as the extra 38mm i believe would be alot more trouble in the S chassis, i could be wrong though
Thanks.
hi mate it wont fit. guy here has a rb25det in a s14 and the bonnet wont shut, so he bent it in a bow shape to shut, cars a track car so not to bad, but looks shite. :laugh:
Edited by rockabilly
I'm looking at removing the powerFC from my RB30DET for use in another car.
The engine is using a standard RB25 loom and injectors/sensors, the only difference being I don't use a boost sensor.
What are the chances of simply plugging-and-playing a standard R33 computer into it and driving away?
The standard r33 ecu is more than capable of running the 25/30DET, but the base/factory tune will be rubbish and would need to be retuned/chipped anyway.
Cheers, so by retuned, is it a simple task of just adjusting the CAS and whatever else to work with the slightly different engine, or are we talking a major effort to get it up and running? Also, without the boost sensor will it do stupid things (like retard the timing)?
I assume from your statements that you are running a D-Jetro PFC (MAP sensor)?
To run it on a standard ECU you will need to throw an AFM in there. I will also guess that it will max the standard AFM pretty much straight away and run in R&R most of the time..
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
