Regardless more than 7.5k and u really should be running an aftermarket balancer.
So its either you go all out or you don't.
Standard rods resized with new bolts.
Price up what you want done to the std rods and then compare the price to spool import forged rods and you will see why its useless spending $$ on the stock rods.
has any one tried their luck with grabbing their series 2 motor from a wreckers then slappping the head on with new head gasket>?
like not touching the rings or bearings in the bottom end???
I know a couple of guys who have whacked together something rough and cheap, seems to be working fine for them pushing decent power? You looking into doing it yourself?
its just an idea at this stage as my motor seems rather heallthy...
the factory hone marks are still looking good.
i was thinking of putting rb30et oil pump and that being the only real change to the bottom end..
will be chucking in head oil restrictors also...
im havingtrouble finding any place tha can suply the tomei press fit oil restrictors...
what kinda of power figures are your mates cars running???
im running a hks T04e turbo.. i cant imagine it flowing enough to get anything over 270rwkw..
ill be happy to get over 200 at the wheels..
i have just brought dahtone racing (from this forum) head from his 32 which has been ported and running gtr valve springs..
all i would be buying would be genuin head gasket a idler and a genuine water pump and thermostat....
oh reallly..... maybe not such a good idea with the restrictors aswell as the 30et pump??
wat pump would you suggest going with...
my other thought was a rb25det pump....
was not sure if you needed the crank collar if you went with the series one oil pump???
cheeeers
cheeeers
yeh i would suggest the rb25det oil pump few of the guys suggested that to me also. you should get 200 at the wheels easy just whacking it together, some guys on the forums are talking fairly big numbers, but even saying that iv been told the factory bottom end can hold upto 500hp.
I saying that say you spend 1g max putting the 30 together on a very cheap its not gonna hurt as much as spending 5-6k and blowing it up right?
you should use a thicker gasket maybe?just an idea but im planning on using a multi layer rb26dett.
Im planning on using restricters with the 25det oil pump? Is this right/wrong?
Edited by Redliner007
Why not to use an RB30 oil pump... well it's just a bit skinny. Restrictors will be good with the 25/26 pump. Don't need to drop the CR at all so just use a single factory 25 head gasket. The collar is a damn good idea, and Nissan eventually made it standard across all RBs I know of after the 33GTSt and later model GTR32s to give a wider oil pump drive.
thanks for the offer geoff....but dad ended up getting a whole 26 head the other week anyway. So i need to change that sig now lol...Even so, we wouldnt have needed the idle control anyway...race car we just do it manually...one less valve, less weight and clutter :thumbsup:
what about leaving the stock rb30 oil pump and not running any restrictors or anything????
i planned on just using a stock nissan rb30 head gasket...
its my understanding that to fit the crank collar the crank has to be removed from the block and fitted professionally, is this correct????
cheeers
ps just ordered my dayco timing belt threw repco, cost me $60 cuz they had to order it..
what has anyone paid for a genuine rb25 idler???
haha yep ripco for sure ay...
spewing. as their is also a sprints in my town too...
oh well repco is just a pushy ride away and already paid for...
where abouts can ya purchase the head oil restritors??
yeoooowww
anyone got a spare rb25 idler sitting around??
haha
I would presume the stock rb30 pump should be ok with stock restrictors.
I remember some one on ct.com had issues with pressure bleeding off on idle with the rb30e pump. Unsure if it was a stuffed bottom end, pump etc.
Wouldn't use an idler. Use 2 x tensioners.
oh okay rekon i go with two tensioners.... its best to determen where to drill the hole for the second one after you have your timing belt?
so to get the right tension kinda thing??
salesman and a half you are dahtone.. haha im already in debt to ya..
does crank need to be removed to fit the crank collar??
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
