from memory it depends which power steering pump you are using, and if the belts line up correctly. Assuming the alternator/water pump belts are the same.
but for the price of the ross units why not just get one of them?
Agreed!
its a standard rebuild that im doing so i dont need the ross
I was going to use my r32 one but for the price i might as well get a new one. I remember sk posting that he uses mostly rb26, i think ill have to do some old fashioned belt checking and see if i can do the same. Otherwise im sure the rb20 one will be fine
Actually cubes will know, where are you old mate?
Edited by Gts30t
  • 3 weeks later...
hey all,
slightly off topic but im in n.z and i have a spare r32 non vct rb25de head that im thinking about selling, just wondering how much should i sell it for?
i have had it vacuum tested,crack/pressure tested and have had the valves all checked and have had it dipped to clean it all up. Only thing wrong is the exhaust valve guides have a tiny bit of play in it. The head is disassembled also but everything is there to put it back together i.e springs,valves,camshaft,gears etc.
I also have a r33 vct head that im thinking about selling what sort of price could i get for that? would it differ compared to the r32 as the r32 head are harder to find?
They both (with manifolds) go for around 1k these days.
The R32 rb25de heads can sometimes fetch a little more due to the no fuss bolt on and go.
The r32 rb25de has 'slightly' smaller but rounder ports compared to the rb25det vct head. Regardless they don't appear to give anything away in the power making vs boost side of things.
Only real issue is both heads are hydraulic of which limits total power output (400rwkw max) on pump fuel due to the inability to run cams with decent lift 10-11mm.
i only have manifolds for one of them which im using for myself. how much do you think i could get just for the single head which is unassembled? A guy has offered me 450 in bits for the r32 head?
Correct but the tomei solder lifter kit requires a cam with a smaller base circle. So extension shimming would be required.
There is a mob I have the number for that apparently converts the hydraulic lifters to solids. Have yet to contact him to find out the details cost etc.
I'd personally machine the heads buckets, grab the tomei solid lifter kit, suitable springs, reco the head and then have Tighe cams grind up a set of billets with 11mm lift or so.
Yeah the only reason i ask is because its a good upgrade for a RB20 i heard and i have a RB20 atm and having the 30 being build (well getting parts together) and just thought i could put them in my RB20 for a upgrade while i wait for the 30 then put them into the 30.
But if i have to machine the 20 head then the 25DE head then theres not that much point as i dont want to do much to the 20.
lol bad boy bubba.. I love cats.. I wouldn't wrap one in gladwrap :kiss:
I looked into solid lifter conversion with some big cams and it came to about $2500 in just parts, then gotta add machining and downtime to that!
I'll stick with my stock NA cams for now..
JHH Engineering in qld does the solid lifter conversion for roughly $450, then add $1250 for cams & gears.
I just picked up a big head from them for a friends car im building (26/30 in a 33gtr), labour on the head was $3130 ($6k head in total)
    • Had a chat to Tony Mamo - he advised that looking at the graph's shape (regardless of number translation) it shouldn't be levelling off like that up top. He said it looks like the car is running a restrictor plate or something of that nature. Luckily the last dyno pull on E85 was saved to the PC - So I did a quick trace of Barometric KPA vs Intake manifold pressure, and lo and behold I see a copy of the 'waves' I was seeing on the dyno: I'm not entirely sure how to go about addressing this. It may be worth sacrificing IAT to run a more direct intake for the motor. Though packaging this could be flat out impossible given the constraints of the car. I should have removed the intake pipe to see if this made a difference but looking at this graph I now have something to potentially test in the future and think about.
    • Oh, I forgot too, all the multimedia stuff captured and sold through things like people playing Pokemon Go. Pokemon Go specifically, can actually be traced all the way back to a CIA investment company too. So yep, they're watching everything. Not to mention the new stuff where they've worked out how to use WiFi signals to be able to map occupants inside of a building. That one would be something that I see being more used in public/government buildings, as you need to understand the signals when the room has no one in it first. It's not as easy as Hollywood would like you to think it is.
    • Followed ☺️ Assuming those are NEO rods, then at least 400kW all day.
    • Lets keep this going , Spotted this very stock V35 in Penrith and also saw a nice R32 FLY past me on Castlereagh rd , sounded really good.
    • Great work! Give it a clean up with some Emery paper, and I'd run a thread die over the threads too to clean them up. It will make reinstall much easier, and also life easier for the next time it needs to come out.
