i'd like to use the RB20 plenum too for the "stock" look
along with the RB20 cam valley/ignitor cover
Nissan 2000 24 valve :) :)
can the RB30t water and oil pumps be used? would these be better than the 25t pumps ?
also if i had a bare block RB30 where would i fit idlers and tensioners? what sort of $$$ are they worth ?
*bring back the old thread :) *
  • 4 weeks later...
I saw a article in zoom where they had a worked RB26 with cams and huge turbos etc, they then changed over to a RB30 bottom end. Thats all they did, plus a re tune. They left all the other hardware in place. So it is a good scientific example because the only variable that changed was the bottom end.
The engine did not just get some more bottom end grunt. It got more bottom end and shit loads more max power as well, all at the same boost levels.
So engine analyzer programs aside, in real terms the RB30 conversion will shit on the smaller bottom end in power and torque. Sure, it won't rev to 10,000 RPM but it won't need to becuse it will out power the smaller engine at much lower revs.
Nope, nothing different cept bottom end not even boost.
I dunno on the dyno it had fullboost when being held at 2300rpm
On the road i really couldnt tell you as i wasnt watching judging by torque its pretty much full boost at 3000rpm in ramp mode.
4th gear is roughly 35 rpm to every 1 kph i believe
depends on the tyres u are running.. :mad:
I can see how a 4.11 is pretty much required for a RB30.
If 1kph = 35rpm the RB25 made peak power around 6000rpm and the RB30 made peak power around 5200-5300rpm.. That doesn't sound right. Unless the RPM is out 500-600rpm.
Doesn't the RB25 make peak power around 6500rpm?
If that assumption was correct then the RB30 would be making peak power close to 6000rpm which is what i've heard previously.
So what did you have done to the short motor?
Forged pistons etc?
JNR24 I think he is talking about the RB20 Turbo oil pump?!?!
If so that will fit and flow enough.
The R33 GTR + oil pump requires an Adaptor.
The R32 GTR pump fits but apparently has problems with some thing cracking.
The cracking maybe due to rev's however so it may not be a problem with the R32 GTR pump on the RB30.
?!?!? Unless I am wrong.
Joel - when you just increase the capacity of the motor without increasing the volume of air going to it, the point of peak power will move lower... That's why you need a bigger cams, valves, turbo's, etc to make the most of a 3ltr motor.
But for a street/track car - that torque curve and power curve are ideal!
matt
Forged pistons etc?
The NA RB25DE Cams are supposed to be slightly more aggressive compared to the RB25DET cams, not to sure but thats what JMS said?
Sounds good Matt. You can definately see on Raists power curve where the flow restriction begins.
That power dip will be slightly associated with tuning.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
