Hey guys theres an engine being sold on ebay if anyones interested RB25 headhigh mount extractors for a t04 turbo with t3 flange worked with stock cams two inlet manifolds and an rb 25 block Rb 30 block pistons and rods i think for the 3.0l rb block $500.Plus i think all the hard work like matching the head to the block has been done allready.He claims that he has made 770 hp from it in his race car?????Its worth being checked out.But the price may go up because of the bidding.....Worth a look. :flamed:
Thanx Gary,
Which valve springs do you use? A set of GTR springs should will do the job?
Hi Joel, when I said "we always upgrade the valve springs" that includes GTR's. We use Iskenderian.
rob from RIPS is a nice enough guy but what he charges for the work he does its bloody highway robbery... he want 3,400+ shipping for a rb30 converted to take a 4wd sump??????? then wont tell you what your getting done for your money???? WTF
Plus he said that would be standard internal put new bearings???? again WTF
PRIMO check back a few pages the issues of the 4wd system on the rb30 have been discussed there, if you are keen to hold off a few months i am doing all the work required to make this work and will gladley tell you step by step what it takes to make this work its not really that hard as long as you have a good machinist shop you can talk to and access to some cluey engine builder!!!
S13drifter ok when you get urs done let me know i assumed it would not be hard if you had all the machining equipment ,
It is only a slab of steel used to replace the main bearing cradle and also bolt to the exsisting sump bolts ussing resessed bolts the utilising new bolt holes for the 4WD sump am i correct ?
i would assume this would relieve any stress on the block also.
HOLY CRAP. I started at page one. I looked and there was 8 more pages so i went to last and i find out there is 50+ pages.... eek... Anyway great thread. I am looking to to the RB30E.
Does anyone know what the stock specs on the RB30E is? I love in the states so where would be a good spot to buy an RB30 clip or motor set?
The RB26 main bearing cradle is separate from the sump mounting system, same as RB30. The only difference between the RB26 block and the RB30 block at the sump mount is the RB26 block is much wider (mostly at the rear) and has extra threaded holes (further out) to mount the sump, diff and transfer shaft to.
Guys;
Has anyone actually done this and had good long term success in terms of durability and power? I'm keen to do it but a shop in Sydney who has a lot of experience with GTRs and the RB30 conversion on other cars has warned me against it, saying that RB30 blocks are too weak to continually take the torsional stresses of a high power 4wd and are prone to cracking (whereas a 2wd will just light up the rears). I'd be more than happy with 400 4wkw, which it won't see regularly and as it's a daily driver it's the torque I'm after.
I understand RIPS in NZ has a strong GTS4. They don't appear to have a website so I've sent an email and will follow up with a phone call later to see if I can find out more from them.
Thanks for any feedback.
Done some more research on suitable timing belts. Dayco have a belt the same profile as a 94407 (152 teeth) but with 150 teeth, Part no. 94777. This could be used with 2 adjustable tensioners in the factory locations as per the Gates belt setup in Joel's guide. Only issue is this belt is 23mm wide rather than the factory 25mm. Dayco tell me this is not a problem, but they also follow up the e-mail with a disclaimer.... "however please be mindful as we don't list this belt for this application you have requested there will be now warranty to cover consequential damage should something go wrong - we'll cover the belt, but that's it." Probably standard arse covering fare, but it makes me uncertain if it will do the job.
I realise the 94407 will do the job, but why drill & tap another hole and risk ****ing it up if i don't have to.
I'm interested to hear others thoughts on the 23mm belt. Will it hold up to 500 BHP??
heres a rough pic of what the spacer/girdle has to look like to adapt the rb30 block to the rb26 sump (sorry for the crudness of the picture had to be made small and rough to fit).. PRIMO as gary mentioned the crank girdle has nothing to do with the conversion exept the rb26 one has the windage tray as part of the girdle and the rb30 has it in the sump you can either tap holes and fit it to the rb30 girdle or as im doing use the rb26 girdle and get the block and girdle squared and line honed!!!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
