Hey guys theres an engine being sold on ebay if anyones interested RB25 headhigh mount extractors for a t04 turbo with t3 flange worked with stock cams two inlet manifolds and an rb 25 block Rb 30 block pistons and rods i think for the 3.0l rb block $500.Plus i think all the hard work like matching the head to the block has been done allready.He claims that he has made 770 hp from it in his race car?????Its worth being checked out.But the price may go up because of the bidding.....Worth a look. :flamed:
Thanx Gary,
Which valve springs do you use? A set of GTR springs should will do the job?
Hi Joel, when I said "we always upgrade the valve springs" that includes GTR's. We use Iskenderian.
rob from RIPS is a nice enough guy but what he charges for the work he does its bloody highway robbery... he want 3,400+ shipping for a rb30 converted to take a 4wd sump??????? then wont tell you what your getting done for your money???? WTF
Plus he said that would be standard internal put new bearings???? again WTF
PRIMO check back a few pages the issues of the 4wd system on the rb30 have been discussed there, if you are keen to hold off a few months i am doing all the work required to make this work and will gladley tell you step by step what it takes to make this work its not really that hard as long as you have a good machinist shop you can talk to and access to some cluey engine builder!!!
S13drifter ok when you get urs done let me know i assumed it would not be hard if you had all the machining equipment ,
It is only a slab of steel used to replace the main bearing cradle and also bolt to the exsisting sump bolts ussing resessed bolts the utilising new bolt holes for the 4WD sump am i correct ?
i would assume this would relieve any stress on the block also.
HOLY CRAP. I started at page one. I looked and there was 8 more pages so i went to last and i find out there is 50+ pages.... eek... Anyway great thread. I am looking to to the RB30E.
Does anyone know what the stock specs on the RB30E is? I love in the states so where would be a good spot to buy an RB30 clip or motor set?
The RB26 main bearing cradle is separate from the sump mounting system, same as RB30. The only difference between the RB26 block and the RB30 block at the sump mount is the RB26 block is much wider (mostly at the rear) and has extra threaded holes (further out) to mount the sump, diff and transfer shaft to.
Guys;
Has anyone actually done this and had good long term success in terms of durability and power? I'm keen to do it but a shop in Sydney who has a lot of experience with GTRs and the RB30 conversion on other cars has warned me against it, saying that RB30 blocks are too weak to continually take the torsional stresses of a high power 4wd and are prone to cracking (whereas a 2wd will just light up the rears). I'd be more than happy with 400 4wkw, which it won't see regularly and as it's a daily driver it's the torque I'm after.
I understand RIPS in NZ has a strong GTS4. They don't appear to have a website so I've sent an email and will follow up with a phone call later to see if I can find out more from them.
Thanks for any feedback.
Done some more research on suitable timing belts. Dayco have a belt the same profile as a 94407 (152 teeth) but with 150 teeth, Part no. 94777. This could be used with 2 adjustable tensioners in the factory locations as per the Gates belt setup in Joel's guide. Only issue is this belt is 23mm wide rather than the factory 25mm. Dayco tell me this is not a problem, but they also follow up the e-mail with a disclaimer.... "however please be mindful as we don't list this belt for this application you have requested there will be now warranty to cover consequential damage should something go wrong - we'll cover the belt, but that's it." Probably standard arse covering fare, but it makes me uncertain if it will do the job.
I realise the 94407 will do the job, but why drill & tap another hole and risk ****ing it up if i don't have to.
I'm interested to hear others thoughts on the 23mm belt. Will it hold up to 500 BHP??
heres a rough pic of what the spacer/girdle has to look like to adapt the rb30 block to the rb26 sump (sorry for the crudness of the picture had to be made small and rough to fit).. PRIMO as gary mentioned the crank girdle has nothing to do with the conversion exept the rb26 one has the windage tray as part of the girdle and the rb30 has it in the sump you can either tap holes and fit it to the rb30 girdle or as im doing use the rb26 girdle and get the block and girdle squared and line honed!!!
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
