heya people..
anyone know the diameter of the crank at the main bearings and big ends? just to be able to check the block/crank for wear, only picked it up today .. trying to get a guage on the things needed.
Joel , you mention that the RB25 water pump has a different bolt pattern. this mean its not usable? or just that the one bolt doesn't bolt up and you can leave it?
as anyone played around with the teflon style paints for the interior of the blocks to assist with oil draining back to the sump?
Edited by Craved
I'd like to hear about fatz tight arse also. :)
On the note of block -> head oil restrictors, can't remember if I covered it in here.
RB20/25 - 2 x 2.4mm
RB26 - 1 x 2mm
RB26 N1 - 1 x 1.8mm
RB26 Tomei - 1 x 1.5mm
RB30 - 2 x 1.8mm
Be sure you block one off fatz.
As I'm running the rb25 head I'll soon be running 2 x 1.5mm tomei restrictors. They pin punch down on top of the origional ones.
Running 2 x 2.4mm restrictors my rocker covers are being filled with oil even though the return had been honed to improve oil return. :laugh:
BUT I am running a rb25det pump that sees ~6.5kg/cm2 or what ever it is at high rpm.
I know some one who has a spare.
New from tomei, I believe they are worth ~$30. There is a mob in australia that makes them up also. I forget who they are but they are well known. :
ahh ok, will look around, might also ask my mech if his engine builder can fabricate or locate them for me..
pretty sure he'll want to know about it, think he is building an RB30 for majanal's r33 ..
Joel, your guide says you need to adapt another oil return line from the head when using the R33 RB25 head
is this just a modification of the existing return from near the power steering pump? to return into the turbo return line rather than back into the block direct as standard on the RB25?
will check it all out tomorrow. i have my S2 block at home now finally..
see if there is a related return point on the block like the RB25 ..
http://img68.imageshack.us/img68/8546/untitled1ko.jpg
is a pic of the RB25 return... see if something corresponds on the rb30 block.
i'll have a look tomorrow, im at work at nights so i can check when i get home ..5am :)
but by the look of that pic i posted before.. it looks like it connects to the white rubber hose just below the exhaust runner from Cyl 1..
had a long google search.. found these 2 shots that show the return for the head
eng4.jpg i know its small link http://www.japimports.com.au/products/jap/...images/eng4.jpg cos pic wasn't showing for me
Edited by Craved
i would only suggest running that oil drain on your 30DET if you have re-routed the VCT line so you can use it. the VCT oil feed (via the front cam bearing face trench) is quite a large one, much larger than the other cam bearing oil feed holes.
in addition to this, it does not matter if the VCT is ON or OFF, all that oil still gets dumped back into the head somehow, so you're ALWAYS getting a fair bit more oil in there.
thinking about it logically, any RB25 head that doesn't run VCT from the factory didn't have that extra drain. so if you've disabled your VCT, don't worry too much about the extra drain.
Another concern is the rb25 heads that don't run vct also ran lower pressure oil pumps.
I've seen this already with regards to bl4ck32's motor. Its identical to mine apart from the oil pump (rb20 for him, rb25det for me), literally identical as it was built at the same place at the same time.
Higher oil pressure at high rpm does squirt more oil in to the head, possibly one reason why the N1 motors with their slightly higher pressure oil pump ran a smaller oil restrictor.
I don't think its black and white, there are many variables. :D
double checked on a mates R33 while on lunch, there is a fitting tapped into the block just behind the power steering pump, have to look to see if there is a flat surface on the RB30 block that matches that can be drilled out to supply the drain location..
found a side on pic of the rb30 block on meggala's site
doesn't look like there is an available point to tap into for the return line...
perhaps just straight into the sump itself, or into the turbo return.
Edited by Craved
Im also interested in the whereabouts of the restrictors..got a 25det head going on rb30e block.
As for that oil return I would say maybe into the top wing of the sump somewhere. Though the guide says T'ing into turbo oil return, if its not a great thing to do maybe add that to the guide joel and when we come up with a solid 2nd solution it can be added.
Cheers.
I know of a couple people that have T'd in to the turbo oil return, they are having no problems.
I know of one person have problems and they are T'd in to the return. It could very well be something else, they are running the N1 high pressure oil pump without modification of oil restrictors. Possibly the real issue.
just got the g/bos off the rb30, checked it out, there is definately no where to tap into on the rb30 block for the return line on the rb25det head..
also noticed that the heater line connectors (the green agrden hose type fittings) from the rb25 have the screw points but are not open, im guess you have to drill those out to get the water feeds.
anyone be interested in better side shots of the 2 engines next to each other for comparison? can take some once i go get another engine stand.
i'll flip the rb25 block i have over and see where that taped line goes to, if its just into the sump then im guessing it would be fine direct into the sump on the RB30 ..
just thinking about the volumes of these return lines, if the volume gets too high it might cos a block
in the system and not allow the oil to return fast enough.. just a thought.
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
