Iv got a custom plenum and i cant find where to put the blowby hose. I got the plenum with the car and im lost where to put the hose as im starting to detail my engine bay and keep on the good side of the cops. any idea where it goes or what to do?
Cheers
Dave
MY ENGINE
https://www.sau.com.au/forums/topic/154299-custom-plenum/
I got the plenum with the car so i have no idea where to get one or how much its worth.I like the catch can idea where could i place it in my bay and is it a defect, If it is i recon welding a nipple on would be the next thing i would do but will this change the engine performance in any way?
https://www.sau.com.au/forums/topic/154299-custom-plenum/#findComment-2872095
i bought one of those relocated throttle body plentums and my mechanic refused to put it on unless i had a safc or something,
he grabbed a genuine greddy one and showed me/explained how these stock ones front goes low then high then low presure so you will have different volumes of air in the plentum.. when the greddy ones start high and wide then thin/lower towards the back to keep the presure the same across all cylinders..
he rebuilds engines allday and has every kind of machanical degree so i sold it ahah anything he doesnt like i wont buy but ohwell i respect his knowledge n experiance.. i really liked it though ahaaha
before and after dyno runs would be very interesting
just looked at your photo and you can see how they incorperated what i was talking about into that one, looks rediculously clean and very well made !!!
Edited by 2gceffy
https://www.sau.com.au/forums/topic/154299-custom-plenum/#findComment-2882926
So ur mechanic recoommended a Greddy intake over the cut and shut stock item?
I see what he is saying about airflow, makes perfect sence. I think i will take his advice too.
https://www.sau.com.au/forums/topic/154299-custom-plenum/#findComment-2884749
For those who want a longer cable for there forward facing plenum. I used a throttle cable from a u12 bluebird with an sr20de in it and it fits perfectly.
just to let u all know not to do the front facing conversion on the factory one
i had one on my car they dont work at all
as the other guy said the air flow goes straight to the back and goes in the back cylinder there for the back cylinder is putting in twice as much fuel and air then the others.
thus in this wears out ur motor and use alot more fuel and gives u lest horspower
https://www.sau.com.au/forums/topic/154299-custom-plenum/#findComment-2884916
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
