hey guys want to do a turbo and injector upgrade, i got the turbo sorted-gcg highflow, im just seeing what options i have for injectors, i not worried if theyre used as long as i can service them, also i would like cost effective ones cause on a bit of a budget, whats out there guys cheers
also i have pfc
https://www.sau.com.au/forums/topic/154306-injector-options/
Nismo 550/555's (cant remember which), i had 740's... never missed a beat
Drop in, no problems.
There are other cheaper ones, Deusch works or something couple hundred cheaper
Sards require a bit of farting around so the cost saving isnt worth it
The nismo inj are pretty cheap now as apposed to probably a year ago.. i got a quote from perfectrun.com.au for $800 to my door.. so in effect if your going to do the works (well not the works just big power) then they will be good for you.
Have many people used the deatchwerks injectors? Just wondering wether its worth risking a motor for saving 2-3 hundred $$ if shit hits the fan like a faulty injector...? Can anyone shed some light on this cos the deatchwerks injectors have to be the CHEAPEST ones i've seen... by far unless its 2nd hand lol
They use the Jecs injectors i think... the standard type nissan inj. ( I could be wrong )
I have a set of 555cc injectors from Deatschwerks. I have read of at least 3 others on this forum using them as well.
Mine have been running for about 2 months and haven't had a problem. The car hasn't been tuned for the new turbo or injectors yet, I just made the appropriate corrections in the PowerFC. I haven't seen them go over 70% duty cycle yet, so they will definately flow enough for my power target.
They re-use factory injectors and replace the main components (buckets and pintle caps I think). The price also includes new o-rings, and you get a pretty flow report with specs for each injector :happy:
Having said that, after reading that thread a couple of weeks ago on shaving injectors, I wouldn't be suprised if that is all it really is, just a high tech version of.
They re-use factory injectors and replace the main components (buckets and pintle caps I think). The price also includes new o-rings, and you get a pretty flow report with specs for each injector :P
cheers i think im going to give deatschworks a go, yeah 555cc injectors will be fine for my power levels, how long where u waiting from payment to delivery?
Edited by s13onevia
Around 7 days from memory
Yea give or take around 7 days... I purchased a set then i wasn't confident in them so i sold em LOL
It worked out cheap... really cheap especially with the rebate! if your standard injectors are good like Lazy-Bastard said you get $25 USD back for em each... works out to around $150usd, the exchange rate will give you about $200.. so in effect your paying around $350 for the injectors... not bad ey?
I just want to know everyones personal experience with the inj, they use the Jecs inj like Lazy-Bastard said, but hmm... i just dunno... I wonder what the moderators think about these inj and the risks involved (if any)
I just recieved my set of Deatschwerks 555cc Injectors on Thursday. took less then 7 days to arrive and will be getting them fitted and tuned using a Haltech E11v2 later this month. I will post up the results including dyno print.
Cheers
Cheers
Like i'm sure they would be fine with the tune and the results will more than likely be as good as having sards or nismos in there, but what i'm concerned about and i dunno if anyone can vouch for this is wether they will go the distance? i've read the jecs ones leak around the seals or something like that, some people complaining and crap but yea i suppose its pot luck with alot of stuff you buy... even rebuilds can turn to shit cos the tuner/mechanic didnt take the right measures for the abuse the motor is due to take... which i've seen with a few workshops in melb which friends have been to with their cars...
But deatchwerks always say "if there is something wrong with them just send em back to us" and they will replace them.. they're REALLLY REALLY good to deal with and they arn't ones to hide even tho they're in oaklahoma usa.... but eh i suppose its only worth a try
Deatchswerks have supplied thousands of automotive customers through out the years and they seem to be providing a high quality, reliable and excellent priced product. There are many 800 - 1000Hp machines using Deatschwerks 1100+cc high flow injectors without a problem...
When ng on the "shaved" injector theory, the standard RB25DET injectors flowed at approx 720cc with the entire pintle cap removed, therefore a 550 to 720cc highflow is more then capable for the stock injectors.
Cheers
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
