Hi guys,
I just finished installing my Hybrid FMIC and took it for a test drive only to notice the car performing worse than it did on the stock intercooler. The Stock boost gauge in the skyline is reading above 7+, but like i said the car just isnt anywhere near as quick.
The Cooler size is 600x300x75 and the turbo is running 14psi. Everything else on the car is stock.
What could be causing this problem?
https://www.sau.com.au/forums/topic/154312-fmic-install-causing-problems/
  • Replies 41
Posted Images
110% thats your problem.
You shouldnt be running 14psi to begin with.
12 at the max, and only with management/interceptor at that.
If you dont have:
Exhaust
Better panel filter
Some kind of management
Then running 14psi is madness dude.
Back it off to around 7-8psi till you get everything else.
FMIC should be the last thing... and even then its not even needed :miner:
Its a R33 Series 2. I'm running full boost because the kit i used didnt have a nipple for the boost controller.
Although its running full boost, it just doesnt go the same as it did with the stock intercooler.
Even if i did back it off to say 7psi, i doubt it will go any better. So what else should i check?
lol dude why would you put a cooler on first???
ive just installed my catback, waiting for my dump/front pipe before i get my cooler on, after that will i boost it to around 11-12 psi. (s2 gts-t)
Oh dear - Start putting pennies away for an engine rebuild me friend, your engine will self destruct shortly.
Did you install it yourself? No competent workshop would have left the car running unlimited boost.
if there is no nipple on the cooler piping for teh actuator... how on earth do you control boost?????????? let alone making your stocko boost controler work?
You plumb the hose in elsewhere the same as everyone else does, you dont leave it off and hope for the best
ok leaving it off would result in yout turbo always making more and more boost (theoretically as i have never tried this) but in saying that i dont know what your boost controler does to the computer when it doesnt find a value to report on.
hence why its prolly running like sh!t.
but somewhere from the turbo to the intake plennum you need to plumb the turbo actuator line in.
I had the same problem when mine was installed (i did not do it myself) the mechanic tee'd the line running to the wastgate into the bov hose as there was no nipple, would run about five pound or so till stage two boost then it would hit as you said the +7, you will need to get a nipple TIG welded where the nipple on the standard cooler pipe work would be. Why these kits don't have em is beyond me...
dude your not set at +7 (14psi) its set at INFINITY... you will blow it up awful quick. No ecu can handle that safely, the stock one will not know how to fuel it and cannot stop it from spinning, so u get bogged down.
you need to intersect a vacum hose ove on the intake plenum, and run a hose from that to the stock boost control. buy a 3x5x3mm t piece for an air hose and a 4mm hose about 1.5m long. Easiest but not best spot to T it is to the fuel regulator's boost signal, its on the front of the plenum and goes from the fuel rail about 6cm long to the plenum. Sorry i dont have the technology to take a pic (camera) but perhaps there is one out there somewhere?
Sounds like the ECU is hitting R&R (Rich and Retard) due to too much air flow through the AFM. You need supporting mods to be able to run that much boost and even then 14psi is the max that you should EVER run through the stock turbo.
Yeah i did install it myself. I know its not safe to run the turbo as it is right now thats why im not really pushing it but i didnt connect the controller because i didnt know where i could have connected the boost controller after the install since it didnt have a nipple on the trottle body pipe. I cant seem to find that line where i can place the t-piece. The kit did come with about 1 meter worth of hose and a t-piece but i havent got a clue what i should intercept.
Can someone take a picture of the line jeffworld2 is talking about or can someone circle the line in the photo provided?
If i can put the controller back on without getting a nipple welded on that would be awesome.
Thanks for your help guys. Much appreciated.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
