I get this same problem. Anyone who gets in the car for the first time chringes with the noise.
If there is someway to fix it, I'd love to. It sounds aweful! The only time my trim has been taken off is when I got the windows tinted. My b/f said something about the glass not being in the track properly or something....
Anyone got anyway of fixing it??
https://www.sau.com.au/forums/topic/15437-power-windows/#findComment-315762
I had the same problem. I took it to Nissan, who fixed it - apparently it's a loose bolt or something in the winding mechanism. You need to remove the door panel to fix it.
It doesn't take long to do (it took my garage less than 30 minutes) and when it's done you can wind up and down in silence...:)
https://www.sau.com.au/forums/topic/15437-power-windows/#findComment-316320
Does anyone else get that loud clunk when you try to wind up the window when it is currently only 5 inches of the way down ?
To demonstrate it for yourself, start with window closed...Then open the window a bit to hear that skyline guys sick exhaust note next to you at the lights...After he's launched it at the lights and you seem unimpressed at the effort, close your window all the way...and...CLUNK
https://www.sau.com.au/forums/topic/15437-power-windows/#findComment-317399
Demon Dave is right.
I had this same problem, sounded like the window was going to break every time. I pulled the door trim off, and adjusted the rails, and tightened the bolts, as some were loose. No it makes no sound...
Just pull your door trim off, and watch your window go up and down, you'll figure it out...
https://www.sau.com.au/forums/topic/15437-power-windows/#findComment-317460
so i take of the door trim .. what next? do i have to take of the panel between the trim and the outside panel??
i took the trim off last weekend ... but i couldn't get to the winding mechanisms at all ... i was just watching the window go up and down .. but nothing .. it only makes the noise when the door is closed ...
https://www.sau.com.au/forums/topic/15437-power-windows/#findComment-319729
if it only makes the noise when the door is closed, its prolly coz
when the door close the window is forced outwards by the seals as it goes up.
sounds like something is bent out of alignment or the window has dropped at one end.
does one end of the window "drop" first when you start to wind it down from the closed position with the door closed?
one of these days i will fix my own drivers side window - hadnt worked for about 8mths. funny how you get used to things :D
https://www.sau.com.au/forums/topic/15437-power-windows/#findComment-320022
this could be worth a try....
with the trim off, from memory you will see 2 adjuster bolts at the top of the door at each end of the window. these can be loosened off and slid up and down to adjust angle etc.
its possible one of these might have moved/dropped.
you can usually see where the original factory position was due to scratches and marks on the paint.
mark the current positions of the bolts before you start moving them so you can move them back if you need to.
the side that drops down first when you start winding the window down is the side i would raise a tad.
https://www.sau.com.au/forums/topic/15437-power-windows/#findComment-320301
dan_the_man Prepsol will get silicon off , not sure about on tinted windows tho , but its used to prep paintwork .
I just recently had my door trims off to fix my door locks after having central locking hooked up to the alarm (they left a retaining hook unattached ) . I thought I'd have a look at the clunky windows while it was all off . Once the door trims are off , peel back the plastic so you can see inside the door cavity .
I found that adjusting the two top brushes eliminated the wobble in the windows . Also the window was coming down unevenly . There is an adjusting rail right in the middle of the door . It has 2 6mm nuts about 20cm apart u need to undo . Play around with this until you work out the right way to move it to make the window go up and down evenly . Worked for me .
https://www.sau.com.au/forums/topic/15437-power-windows/#findComment-321568
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
