OK. im cloging up the place.
r32gtr airbox SOLD
r33gtr/34gtT nismo gmax 2 clutch. 90% worn $150 ono
r34gtT gearbox with nismo clutch/flywheel almost new. excelant condition. suit upgrade or conversion $2000 ono. SOLD
pics of the clutch. gearbox soon :)
dr30 coupe doors. complete.with windows and all trims. very good condition $250
dr30 taillights. early type unfaded. $125
dr30 instrement cluster with vdo digital speedo and 8k tacho. autometer water temp and fuel guages. 395 ono?? (cost me 950 ti put together)
1 piece dr30 tailshaft to suit the rb25 gearbox. (large yoke) $150
rb26 sump thats been modified profetionaly for RWD $150 SOLD pending payment
1000cc top feed injectors BRAND NEW!! low impedance.8 IN TOTAL suit rb26 rtc etc $395.
R33gtr injectors freshly reconditioned SOLD
im located in sydney.
pm for more detales and for my number.
https://www.sau.com.au/forums/topic/154747-many-parts-for-cheap/
hmm. dooors, i uset to have a 3.5 inch catback.
i have a full vdo instement cluster (white dials) complete with a 300k speedo. and the gearbox/clutch/flywheel were all out of it. (rb26 powerd)
so your saying you had a Rb26 in a DR30???
where is it! gotta show some pics!
can i have pics of lights and dash...might get them both from ya...
and what happened to the catback???
need more details mate!
yeah thanks,
i guess it would be cheaper for me to buy whats left and get new bends put in than to buy a whole new one....
Im building a R30 with L24/L20et setup... nice simple torquey daily driver.... but with a 3" at lest it will go a bit better!
I know its a long shot but you dont have any DR30 coupe seats?
cheers
