hey guys my clutch is starting to go, as i just got my car back with sum mods for street use i always run 350hp, and rarely when i start taking it to the drags il boost it up to run 20 or so more hp what kind of clutch would u recomend for mainly street use and the occasional drags? not after sumthing really expensive
cheers sam
https://www.sau.com.au/forums/topic/154833-clutch-almost-dead/
General consensus is
1a. Jim Berry clutch, very good single plate clutch (about $1200 plus install I thinkl)
1b. Exedy, Australian clutch? village bike (single, twin, puck, button, whatever :laugh: ) From driving my brothers car they seem to be quite heavy clutches.
1c. Nismo Super Coppermix or other Japanese aftermarket clutch ($1500+, plus install). Check Perfect Run, Nengun etc.
2. Flywheel is also a good option for ~$500, install of that should not be much more seen as the though the gearbox out is most of the work.
Whats the price on a clutch + flywheel install anyway?
clutch + flywheel install on a gtst will be around $400 + any parts needed
same on a GTR will be double :blink:
I have just ordered a clutch from slide http://www.slidingperformance.com/catalog/...products_id=239
and have heard really good things about it. and for $500 its a fantastic price. it will be going behind 240rwkw and used for drift and normal street use
I will update with results when it is installed on the 20th.
Cheers
Edited by CEF11E
oh thats not bad prices i think im gonna go for a exedy single plate dont want to spend big bux, not like im gonna drive hard very often mainly on the odd occasions so u thin ka exedy heavy duty can hold around 350, and 380 once a blue moon ?
There is probably a million threads in this section that you could read on the topic :O
bet u sit here all day to wait for a newbie to post then type this
helpful mod u r :D
i bought a Nismo super coppermix twin plate...holds up to 470kw atw
i read up the reviews/ feedbacks...its all good
helpful mod u r :O
No i dont. actually. you'll find i quite often link people where i can.
This forum is a wealth of information :no:
If you wanted to be "helpful" you could post links to the reviews you speak of ;)
i have the exedy 5 puck clutch in now and it BITES like a wild animal. the car feels much better to drive with it.
it does shudder in reverse going up hills like when you back out of a a driveway when you are coming off the pressure point. but it is tolerable.
Xtreme cushion button.Never looked back.
i'll second that!
easy to drive as well ideal for street use with the occassional spirited spurt.
they are pretty cheap as well..$500 for the whole clutch kit
cheers
good to hear!
just ordered one today for my 32 with the chrome moly flywheel as well
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
