what do you all think of this rear bar.. i like it, loox r34 style. some reason the wine red makes it look cheap and maby the mesh is bad on this one :D
R33 GTS AB REAR BAR..
Eew, I didnt know Droid made kits for Skylines.
No offence to the owner of the car if they are reading this, but that rear end makes baby jesus cry.
What do ppl think of the veilside with gtr wing
hey, is this your car?.. i dont think it looks that bad, if it didnt have so many plat parts droping down opersite the exaust, i think it may look good, that loox alot beta from behind then some cars with gtr wings.. for sure.. soe look ugly with there kit, and i dont think this meets ugly, loox unique.. but, i tink that may be a fibre glass gtr wing?, may be why its not looking the best :(
Edited by seriesII
na its not my car, iv got a gtr wing but having a problem finding a good rear bar that will look good with the wing. Iv got a trust frount bar and eye lids just need skirts and a rear bar as im not a fan of my gtr skirts and pods.
Don't have a pic atm but mine has a type m front with the lower grilles taken out to view the cooler better, 400R side skirts and rear bar with a stealth wing. When I got the car, many years ago now, was the only one in adelaide i had seen with the stealth wing but now heaps of skyline's have 'em.
Thats why i dident go stealth wing to many ppl have them and i like the look of the gtr wing(not to high and not to low) just looks so sexy
i second that!.. :D .. stealth wing?, are you talking the wing that is on a 93 till 94 series 1 skyline?
ahh, the stealth wing is the aftermarket boot lip mate... not one of my favourites :laugh:
deriq.
that rear wing is ugly as
hmmmm. thanx for thatk, i was some times thinking the stealth wing was the one on a series 1 gtst r33.. hehe.. so thats what they call that wing.. hmmm.. no offence, not my flavor at all, good for drifting a guess tho :P, but no good for quatar mile races :P .. each to there own tho, its good everyone has different flavors, thats what makes this world with so many options :(
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
