hmmmm. thanx for thatk, i was some times thinking the stealth wing was the one on a series 1 gtst r33.. hehe.. so thats what they call that wing.. hmmm.. no offence, not my flavor at all, good for drifting a guess tho :P, but no good for quatar mile races :D .. each to there own tho, its good everyone has different flavors, thats what makes this world with so many options :P
Um what doyou mean good for drifting no good for drag racing....unless your running like 1000hp and doin high speed runs of like 350km/hr....then your wing aero dynamics wont affect shit
explain to me why in drift comps > formula D for example, why do they take there wings off to drift when doing the sharper turned courses?, and im talking about silvia's with 400hp and less ..
???? and back on when doing more straight courses?
I'm looking for a very simple mild kit for my Series 2 sedan. Is it possible to get a factory series 2 side skirt for my car? As i'm new to the skyline scene and dont really know my way around could somebody point me in the right direction of an aussie site or importer i could get a sedan kit through? Any help is appreciated... Matt.
This is my favourite rear bar and skirts, what is it?
Very neat and tidy - I dont like big grills and mesh and vent and curves.
Looks similar to stock but a bit different, not sure if the skirt are stock or not, and I like the stealth wing.
Anyone know where to get genuine body kits from? I would like to upgrade, but don't want a cheap kit that doesnt fit properly.
what do you all think of this rear bar.. i like it, loox r34 style. some reason the wine red makes it look cheap and maby the mesh is bad on this one :)
R33 GTS AB REAR BAR..
that rear bar looks so bad i think it gave me cancer
Anyone got a GTR Type front bar on a series two? and if so where did you get it from?, any pics would be great!!
Whats the differences when buying a bar for a series two.... is it just that it hasent got the grill atatched to it?
I want to get rid of my standard front bar for a GTR type because the series two bar i have only exposes half of my intercooler wich is a waste!
Dave
Edited by r33freely
we get a quantifyable differrence on cats car by adjusting the rear wing, by increasing angle of attack we can increase rear grip in the wet quite noticeably. These wings have effects at speeds from about 120kmh and up, most tracks in the da series now have entry speeds of 140-170kmh so they are far more than cosmetic.
Rhys millens car is a perfect example of this he has published down force results for his drift wing on his GTO, i just used a mates digital pressure pads and fitted them under the boot rubber stops to get an idea of what worked and what didnt.
Edited by URAS
/\/\/\ Agreed, saw on Formula D that Rhys was bragging on how much his wing helps the GTO, would love a URAS one for my 33 >_<
Really like this front bar(EDGE i think) for the R33, anyone know of any places in Australia that has it?
  • 1 month later...
in MY opinion, any aftermarket kit for r33 make the skyline look 'cheap'
take the s2 r33 for example, i think it looks fantastic with the standard kit, not overly done looks so clean. rims plus maybe a bit of a lowering would look mint.
I love the series II kit. But the orange lens on the front bar is such an eye sore!
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
