BP is the only refinery in WA anyway, so technically it'll still be BP.
Usually other Brands put there own magic additives in the blend...
but otherwise it'll mean 98 will be easier to get in those situations where you would normally have to hunt for a BP... i think everyone here has had that experience at least once.
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2888871
ok... who here every time they fill up on bp ultimate put a bottle of octane booster in as well? ive heard that the fuel in japan is 101 octane and that with our fuel we should put in a bottle of octane booster aswell
that would probably make your fuel 98.1 octane and give your plugs a beautiful orange colour
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2890148
Dan, there actually some good octane boosters out there. Besides orange is pretty.
Can anyone CONFIRM where Peak get their 98 octane from. Is it in fact BP or is it from Singapore?
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2890485
Well this is great news. The only reason I went to BP was because they were the only ones who had it, now that peak and caltex do i'll be able to shop around. Sure i'll probably only save a few cents each time I fill up, but it's more about the principal :laugh: (and the fact that I hate BP because they are always more expensive and bump up their prices randomly with no valid justification for doing so except to rip people off)
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2890902
Well they all change their prices randomly. BP is no different.
Anyway why do you hate them so much. Just think where we would all be if BP didn't sell 98 Octane?
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2890932
Just been on the phone to Peak. They often source their finsihed product from Singapore, but the chemist said their 98 is sourced from a Mobil refinery and is the same spec as the Utimate. I assume Caltex is sourced from one of their east coast refineries but I have not been able to confirm this.
Forgein ayyy! Good info skylion.
Should be cheaper but wont be as they colude to keep prices artificially high. Depending on what, if anything, is used to boost the octane rating, toluene (methylbenzene or phenylmethane) or ethanol it is reasonable to expect your tune up to change. I would be very careful with trying different fuel, check your AFR's and be prepared to make the changes. Hp gains have been made by Skyliners on the East Coast using Ethanol boosted fuels. Caveat emptor
Nicking fuel from the airport LOL mmmmm JetA1
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2891618
imagine running jet avo fuel and having a bee*r limiter!!! = massive flames
pop, pop, pop, KERBANG, wooooooooooooooooooooosh!!!!!!!!!!!!
wouldn't adding ethanol and/or toulene be a good thing for your car as it burns better and cleaner?
if it is i can see how ur tune would change anyway
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2891921
keep it on topic please. there have been plenty if toulene threads before which has covered all of this.
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2892058
    • The part where you claim the car "is done" means you won't...
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
