  • Replies 148
  • 4 weeks later...
Was a tad bored last night. I'd actually like to see something like that - better than a fleet of commonwhores and falcons.
Could you post up a wallpaper size version of this if possible? i want to make it my wallpaper!
  • 3 weeks later...
ey whyte howd you do that??..photoshop..then added effects or what?
also does anyone know how you change the shape of a car and stretch wheels ...like those done by anfo .... i know theres another program you can do that in aswel dont know what it is tho :D
vectored the original up and then add the colours and effects.
you can use photoshop to do the big wheels etc like what anfo did dude, its easy, just enlarge the standard wheels and make sure it all blends in and looks normal and smooth.
also does anyone know how you change the shape of a car and stretch wheels ...like those done by anfo .... i know theres another program you can do that in aswel dont know what it is tho :)
Check out
heres a quickie i did
Love the mags, but im sure ive seen them somewhere before :(
  • 2 months later...
  • 3 weeks later...
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
