  • Replies 41
Posted Images
As long as there is a breather pipe going back to the intake pipe there's no dramas, the tool that put a can in my car before I got it had it all wrong and it pumped heaps of oil out the exhaust. Would work better inline with the breather pipe though (i.e. inlet side of the rocker cover > exhaust side > catchcan > intake pipe) :no:
are u trying to catch cans?
:P
:no:
what is that doo-dad core thingy behind the drivers light infront of the radiator? is that a series 2 thingy?
I don't know, looks like some sort of cooler, I'm guessing it could be auto transmission oil cooler?
yep, its an auto tranny cooler.
as long as you've got a breather on the catch can as well as the other pipe thats on the exhaust side blocked off (the one with 2 coming out of it) you should have no problems.
The passenger rocker cover is still feeding oil vapours back into the inlet side of the turbo.
In my installation, the catch can basically replaces the hose from the passenger side rocker to the turbo inlet (that 'U'-shaped hose coming straight up off the passenger side rocker).
If there is no breather OR it doesnt breath back to the intake pipe, crankcase pressure will throw oil out of the dipstick. When I got my car, there was a hose from the intake manifold > inlet rocker cover blocked off. There was then 2 hoses going from each rocker cover to the catchcan with no breather.
The engine was throwing HEAPS of oil out of the exhaust, I reconnected the hose from intake manifold to inlet rocker cover and it stopped throwing it out the exhaust, instead it started trying to throw it out the dipstick. It was abotu then that I realised it wasn't breathing.. so yes there are wrong ways to hook them up :woot:
ohh i see now, i knew the function of the catch can but didnt know it could build presure.. iv seen catch cans with and without baffles n steel wool n that, why is that in there? capture the vapour and slow things down?...
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
    • That's some really horrible design with the way it's cut/shaped! Is there much damage to the box that failed in? IE, new fork and you can go again, or is it a total rebuild again? Id be trying to build that piece from scratch, and getting some reliefs added in the corner to hopefully stop breakage, and then swapping boxes ASAP, and then doing the same to the currently good working box. I'm assuming hard shifts have not been friendly to it!
