i havent donated and prob wont .but if it was a subscription every 12 months for a nominal amount i would pay . i still think gambling banners are tacky tho esp as there are under age people that use the site just my 2 cents worth
why wouldnt you make a donation?
Hey guys,
I gotta say that it makes me happy that people on here have morals. I like to see people getting involved.
Anyhoo, firstly, the banner has only been paid for, for 2 months and the 2nd thing is that no credit card is required. Its not your typical gambling site. I wouldn't put just any ads on here :P
If anyone has anything specifically bad to say about Partyforfree, please PM me.
Please remember, that we dont just take any banners / advertisers.
Christian
Oh, and I SUPER appreciate all the financial support, the site takes a lot of my time and money. It doesnt matter if the donation is $1 or $100, its the support thats great.
Unfortunately, as donations are not regular, I can't count on them for monthly financial support, hence the banners.
What do we gain by this arrangement...besides money???
The
forum
keeps
running.
Would've thought that fairly obvious. It's not pornography and it's not anywhere near as objectionable as that type of banner. Tune it out and be happy with the forum.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
