  • Replies 122
Posted Images
Stop ripping me off Grant! Hahaha!
Nice kit!
That kit will bring you lower than the Dayz kit too I think, even if it is just visual and not actual as the side skirts (steps) are a lot squarer.
Cheers
Luke
hey on the skirts, do they sit liek the factory ones or do they slide in between the door like most kits?
Not sure how the factory skirts fit, mine do sit on the sill panel and run under the doors.
(thanks Alex, black car, wash - then photograph before the dust settles)
i still dont like hte height
If i want to go lower, i need to get shorter springs (think 120mm length stupid short) and helper springs.
i have a custom coilover in the works from a guy around here. im trying to get a decent price from him and not some stupid 2,000 dollar price tag.
ok, started fabbing up the exhaust today
i have all the piping from the cat to the sway bar done. i have to pick up some more 3 inch pieces and pie cut and weld them to make the s shape right there.
my aero will be here friday
my gauges should be nere in a week and a half
ORdered a greddy oil filter relocation kit
Ordering NRG Fuel pressure regulator nad AEM UEGO monday
ordering cusco r33 GTR sway bars monday
and hopefully have my wheels sold so i can get some 9s in the rear so i can go uber low.
Where the hell are you gonna relocate your oil filter to, Grant? I can't find anywhere decent to put one without it then being in the way of something else! Most people with Skylines, etc. put them on the front of the driver's side strut tower, but the Stagea has a massive fuse box there, so that kinda rules that out...
pics
fo sho they fit great now!
can you take some closer pics to show what it looks like up close.. and i forgot what else i was going to say :rofl:
nice car anyways :( coming along good. wich i had millions of dollars spare like you
:Shrug: it is the kit specifically for hte stagea. ill have to take a closer look at the instructions to find out where. but its not a universal kit, so it has to go somewhere
what do you want more pics of?
when i get my kit i will sell you the skirts
So whats thie Dayz thing?
i saw the badge but i dunno what it means
thanks i have only just been able to log back on and finally came across this....thats excellent thanks champ..let me know when :wub: send us a pm on what price you would be after and freight to perth :no:
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
