hey guys, my car is back up for sale! its time for a change and have my eyes keen on another car, but if you have something other than a skyline for trade, hit me up and i just might budge. cash adjustment mine or yours, whatever.
its an r32 gtst with 140k on the clock and 110k on the engine. engine was swapped over as i spun a bearing on the old one. i WAS looking for 14500 bout 2months ago (feb), but have just put in hks hipermax fronts with tein rear coilovers, mechanical 2way LSD and just paid 1years rego. I also have a brand new Vertex front bar not fitted as i like my 'drift scarred' vertex fronty LOL.
so with that aside, im looking for $15,500 $15,000.
Engine and Driveline mods
ATP T3/T4 hiflow
Nismo 555cc injectors and resistor pack
z32 air flow metre
Dr. Drift remapped ECU
Turbotech boost controller
Denso Hi-flow fuel pump rated at 500HP
Exedy heavy duty clutch and flywheel machined
Replaced clutch thrust bearing
genuine C’s short shift kit
Stainless steel intake pipe (turbo to pod)
HKS pod filter
3' Pacer Maker Front pipe
3.5" cat-back exhaust to a 4.5" Cannon tip
3" High flow cat
exhaust control valve (lever you pull to make ur car 10dB quieter. good for the police)
custom in-cabin fan switch (turns on a 2nd fan for the engine, for those hot days in traffic)
Exterior
Full Vertex kit
Front Mount Intercooler 600x300x80
16†2-piece Japanese Modena lightweight rims + r33 black rims for spares
Rear wing removed
Clear indicator lights
Mtec HID look bulbs
Front eyelids
Suspension and Handling
Mechanical 2way LSD
HKS Hipermax front coilovers – fully adjustable
Tein rear coilovers – fully adjustable
Tomei hicas lock
Whiteline front strut brace
4 brand new tyres
Interior
Nismo front floor mats
Genuine rear Skyline floor mats
Pro Con Boost, Water and oil Gauges
Pioneer Speakers and JVC head unit
Factory Sunroof
Tinted Windows
Turbo Timer
Extras
new unpainted vertex front bar
Raizon volt stabilizer kit
Replaced all coil packs, thermostat, water pump, ignition module and alternator
Full 100k Service done
New radiator
New radiator hoses
New battery
Paging alarm system
Stock muffler (for epa)
exhaust manifold gasket
stock suspension
spare alternator
stock injectors
PM me, call Miguel on 0432315388 if your interested, or email me at [email protected]
https://www.sau.com.au/forums/topic/155710-r32-gtst-melb/
yehp ill let you know bud. not interested in interstate cars 'cause i really cant be bothered doing all the interstate rego changeover and that kinda stuff at the moment
https://www.sau.com.au/forums/topic/155710-r32-gtst-melb/#findComment-2899453
  • 2 months later...
nah no dyno graph, but made 175rwkw on 12psi at dr.drift. was previously running at 15psi with a wolf 3d and made 198rwkw, but i wasnt happy with the ecu. current power band feels much better and suits my style of driving.
https://www.sau.com.au/forums/topic/155710-r32-gtst-melb/#findComment-3064267
swap a r33 series 1.5 type m let me know
https://www.sau.com.au/forums/topic/155710-r32-gtst-melb/#findComment-3064834
going to miss it being parked in the garage :) , but all good things must come to an end. hopefully to make way for a fat assed s14 im looking to buy. c'mon people!
https://www.sau.com.au/forums/topic/155710-r32-gtst-melb/#findComment-3070235
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
